Replacing pop rivets??? - Fiberglass RV
Old 08-28-2011, 10:21 PM   #1
AlbertaBound's Avatar
Trailer: 1976 Triple E Surfside
Question Replacing pop rivets???
Hey folks!
I am wanting to take off my fridge/furnace outside vents and paint them. they are attached with pop rivets.
I am guessing I drill them out....
What do I replace them with?
Any thoughts on what type of paint I should use for the vents? (high heat I am thinking?)
AlbertaBound is offline   Reply With Quote
Old 08-29-2011, 10:20 PM   #2
Scott S.'s Avatar
Trailer: 1975 Surfside TM14 (front kitchen)
Manitoba
Send a message via MSN to Scott S. Send a message via Yahoo to Scott S.
yup, drill the rivets out and replace with nuts and bolts (stainless steel). I had my heater panels powder coated so they're good forever. not too expensive if you pick a color they do every day.
Scott S. is offline   Reply With Quote
Old 08-30-2011, 01:38 AM   #3
Thanks Scott!
AlbertaBound!
Old 08-30-2011, 10:46 AM   #4
Hey Scott how did you ret behind the covers to attach the nuts? I think a fridge and furnace are in the way. Should I just replace with pop rivets? Any suggestions?
AlbertaBound!
Old 08-30-2011, 03:57 PM   #5
freddie b's Avatar
Trailer: 78 Trillium 1300
The proper pop rivets are "closed end" but they might be hard to find. Normal pop rivets can be used, just seal the centre hole in the rivet with a dab of something like JB Weld or epoxy to prevent water infiltration. And don't forget the butyl tape.
As for heat damaging the grille paint, this should not be a concern.
freddie b is offline   Reply With Quote
replacing rivets Rick Harmer Problem Solving | Owners Helping Owners 1 01-20-2010 06:57 PM
Scamp and the pop rivets Bruce M. Care and Feeding of Molded Fiberglass Trailers 25 05-20-2008 05:57 PM
Replacing pop rivets in a Scamp Sonny Problem Solving | Owners Helping Owners 7 10-06-2006 05:06 PM
Removing pop rivets... How?? Legacy Posts Problem Solving | Owners Helping Owners 4 04-29-2003 07:13 AM
replacing rivets ScottK Modifications, Alterations and Updates 0 12-31-1969 07:00 PM
» Trailer Showcase
Revive
Squidley
Scamp
Wilder
