Replacing rear dinette 13' Scamp - Fiberglass RV
Old 04-03-2010, 12:29 PM   #1
Trailer: Scamp 13 ft
I need to replace the table and mount new wall hardware. Should I use 3/4" or 1/2" plywood? Or does anyone have ideas for me. Called Scamp and they have to have exact dimensions as each is custom made. I'll make it myself but wondered on thickness.
Bill White is offline   Reply With Quote
Old 04-03-2010, 12:33 PM   #2
Raya's Avatar
Well, if you are going to use the table to make up the bed, there is something to be said for the table thickness matching up to the bench tops at the lip where it rests, which is 3/4" on my Boler.
On the other hand, you probably would not notice a 1/4" dip.
On the other other hand, 1/2" ply by itself is going to sag, so you would need supports anyway.
I think if I were making a new table, I would make something cored, with lightweight ply on both sides and internal stock. A full 3/4" table is a lot to horse around (although, with the scamp lifting hardware maybe not a problem, and 3/4" ply is certainly simpler).
Also, if you only use it as a bed, I find a half dozen or so 1" x 8" x width-of-well to be much easier to handle, and they allow ventilation too (I have the table in storage).
Raya
Old 04-03-2010, 05:41 PM   #3
Robert Johans's Avatar
Trailer: Nest Caravans
I think 1/2" is too thin. With the Scamp table hardware, 3/4" is not too heavy, and definitely the way I would (and do) go...
Old 04-03-2010, 11:17 PM   #4
peterh's Avatar
3/4" birch plywood works nicely and is much lighter than the MDF stuff Scamp used for their tables. If you want to go lighter you can go with 3/8" ply and build up a 2" or 3" band of double thick plywood at the edges and where your table hardware mounts. You need lots of gluing clamps to do the job, but it will make a sturdy bedding surface and table at the absolute minimum weight.
The underside of our smaller pedestal-mount sliding table.
The real question: "Is the extra effort worth it?" The weight and cost savings are minimal, so unless you want to add something like a sliding pedestal mount, I'd say no and just go with 3/4" birch ply.
Old 04-04-2010, 11:18 AM   #5
Attachment 27222
Old 04-04-2010, 11:29 AM   #6
Thanks for the info, I'll get some 3/4" Birch on Mon. Any hints on mounting table hardware? The PO threw out all but the tilt-down post and the two brackets which the table slides into (and these he mounted upside down), so I purchased new wire hingy-thing from Scamp.
Replacing rear window Sandra Lair Problem Solving | Owners Helping Owners 1 05-08-2010 08:27 AM
Bunk over Rear Dinette jenniferm Problem Solving | Owners Helping Owners 1 07-28-2008 05:01 PM
Bunk bed over rear dinette Steph taylor Modifications, Alterations and Updates 15 08-16-2006 08:28 PM
Doors in benches under Scamp rear dinette Chris Z Problem Solving | Owners Helping Owners 14 03-19-2006 09:36 PM
Replacing rear window Sandra Lair Modifications, Alterations and Updates 0 12-31-1969 07:00 PM
