Removed old foam seal (using much effort plus WD-40, brake cleaner, alcohol, Goo Gone, etc.)
Installed new gasket up one side, over the top, and down the other side (with the flange out) right up next to the white door trim. Will do bottom fairly soon now.
Seal is very good. So far, door is a little harder to pull completely closed against new seal. Bottom of side near door hinges came loose once and had to reattach with automotive trim cement (or gasket adhesive?)
Hopefully, others may provide better explanations.
Good luck!
Ray
Sent from my SCH-I545 using
Fiberglass RV mobile app
