Replacing the Campster Poptop roof - Page 2 - Fiberglass RV
Old 06-17-2016, 06:46 PM   #15
Trailer: Hunter Compact Jr.
USA
Originally Posted by Bobbie Mayer View Post
Talia, that's an interesting idea. The only issue is that you need a certain amount of weight to keep it from popping up by itself . But that might be enough weight, hard to tell.
There aren't latches that lock it in the down position? There should be...
Talia is offline   Reply With Quote
Old 06-17-2016, 08:55 PM   #16
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
Yes, but that is another issue- with foam how do you attach the latches? I guess they could go on the frame. Might be different with a Compact as it uses a different mechanism.
Old 06-18-2016, 10:39 PM   #17
When I need to attach something and there is foam between the item I am mounting and the substrate I cut out an area of the foam and replace that section with a piece of wood.
The original latches for the Campster, the upper latch was attached through the popup roof, on through the plywood liner of that roof and then into the fitting itself.
The bottom hook for the latch was screwed through the fiberglass rim of the opening and on into the 1 x 2 wood outside the rim.
I really like the latches, so easy to use and very strong. It is terrific that they are still being sold as brand new affordable replacement parts. I did not know they were hood latches for Jeeps until my friend saw them and recognized them immediately.
They really do work great, there is no need to reinvent the wheel and go looking for a substitute latch. If you look you will likely see the four pairs of holes where the hooks used to mount. You could install the hooks in those holes than hook in the upper part and mark your new roof on the inside for the bolt locations. Use some marine bedding compound in the bolt holes that go through the popup roof, that will keep the water out.
Old 06-26-2016, 10:29 PM   #18
My "loop" parts never left. I just had to add four new hook parts, and yes, it was nice they were still available. I got two last spring to attach the temporary heavy plywood top (only two because I just automatically thought of a "set" as being four!) and two more this spring to attach to the new top.
Did your top have a plywood liner? Mine was covered with wood veneer so I never saw what was under that (if there was plywood or just blocks where the clamps went through.)
campster
An idea for poptop replacement... Bobbie Mayer Modifications, Alterations and Updates 18 11-20-2016 07:41 AM
Compact jr poptop moves too far THOMASJU Problem Solving | Owners Helping Owners 5 02-08-2014 07:34 AM
rremoving old fabric Campster poptop-owner input needed Bobbie Mayer Problem Solving | Owners Helping Owners 22 08-20-2013 10:31 PM
Poptop canvas replacement help needed Ricky 4 Care and Feeding of Molded Fiberglass Trailers 23 12-29-2012 11:00 AM
PopTop for TrailsWest Campster DJ Hirte Problem Solving | Owners Helping Owners 26 11-01-2011 09:14 PM
