Replacing Trillium rock guard - Fiberglass RV
Old 05-12-2011, 02:57 PM   #1
Trailer: 13 ft Trillium
My '72 Trillium came without a rock guard. I want one, as much as anything, to keep beating rain off the front window while on the road. I have purchased 5oz corrugated fiberglass panelling for the covering and now I need to decide on the frame. The local machine shop will make up whatever I draw for them. My first thought was using 1"x1" angle aluminum and holding the fiberglass in place with 1/2" x 1/2" square tubing. Another thought is using 1/2" x 1" rectangular tubing for the frame, with another piece in the middle, and just fastening the fiberglass to the outside of the frame. I will use hinges to fasten it to the trailer with latches on the bottom and held open with prop cylinders. ( The same used to hold open the rear doors on truck caps. I can order them in any length and lb strength.) I'm not the first to retrofit a rock guard and I'm open to suggestions primarily about the frame design.
Thanks,
Barrie
HikeSticks is offline   Reply With Quote
Old 05-13-2011, 04:50 AM   #2
Since the corrugated fiberglass is designed to be fastened to the outside of roof framing I have decided to go with a welded rectangular aluminum tubing frame, with one mid width cross member, and I'll screw the fiberglass to the face of the frame. FYI
Barrie
Old 05-13-2011, 10:38 AM   #3
Roger C H's Avatar
Smile Rock guard project
Pictures when the project is complete, please.
Old 05-13-2011, 11:32 AM   #4
No problem. When I visited the machine shop this morning to order the frame the 1"x1" square aluminum tubing was of heavy enough wall thickness so I went with that. It will be 52"x26" with a cross member at the half width point. Hinges and latches are still being pondered. I will also post project costs.
Shoulder surgery has slowed progress a bit this spring. I will need to take pictures front and back as the project to complete the rear scooter ('82 Honda C70) rack is finished as well.
Barrie
trillium
1976 Trillium Rock Guard For Sale shannon H Classified Archives 3 08-20-2011 09:52 PM
Replacing the center section of the front window rock guard Gumpit Problem Solving | Owners Helping Owners 3 12-03-2010 10:12 PM
Replacing Trillium Window Rock Guard Booker B. Problem Solving | Owners Helping Owners 32 04-21-2010 07:15 PM
Vintage Trillium Rock guard needed Paul McEwan Classified Archives 5 12-03-2007 11:05 PM
rock guard for 1972 Trillium norm & ilona Classified Archives 7 05-04-2006 04:54 PM
