Replacing Water Heater rod - Fiberglass RV
Old 06-10-2009, 06:51 PM   #1
Karalyn's Avatar
Trailer: Eggless for now but looking. currently own Amerilite 21 ft
I spent a couple of hours today trying to screw in the water heater rod so I can have hot water this summer. This is the rod that must be taken out in the fall and put back in in the spring. I have had trouble other years but this yr I just can NOT get the thing screwed back in. I have an appointment at Camping World on Friday to have them do it for me (there goes another $100 bill).
Anyone have any idea how to get the rod screwed in so I don't have to take it to Camping World?
I know it should just screw in, but it won't :-(
Karalyn
Old 06-10-2009, 09:00 PM   #2
Karalyn's Avatar
I got it in,
I went to the "other forum" and went back about 2 to 3 yrs until I found something relating to the problem. I am glad to know I am not the only one having problems with this thing. After three hours off and on of both me and my hubby trying to tackel the dumb rod it finally caught and screwed in.
It is not leaking, and the water got hot.
Problem solved until next spring!
Karalyn
Old 06-10-2009, 09:25 PM   #3
David & Leslie's Avatar
Trailer: Scamp 16 ft Side Bath
Dontcha love it when a plan (finally) comes together? Happy camping! L 'n D
“Imagination is everything. It is the preview of life's coming attractions.” A. Einstein
David & Leslie is offline   Reply With Quote
Old 06-11-2009, 05:37 AM   #4
Karalyn, care to share your tips... the things you found that worked? Others are more than likely going to run into this issue sometime... probably me! Sure would appreciate knowing what to expect.
Old 06-11-2009, 05:56 AM   #5
Alf S.'s Avatar
Hi: Karalyn... Glad you got it back in. FRUSTRATING EH!!!It is a very tight space to put enough fingers in; and trying to hold the rod straight when 99% of it is inside the heater is a trick!!! They aren't exactly light weight either. I used my vise clamps to hold it straight and wrapped it with Teflon tape to give a little slip to the threads and also to prevent leaks. So far So good.
Old 06-11-2009, 08:32 AM   #6
Trailer: 2009 Scamp 16 ft / 2014 Ford E-250 cargo van
I think part of your problem is leaving the rod out all winter.
I would drain the tank leave it sit for a couple of days to dry and then put it back in.
That way nothing can happen to the threads over the winter.
Bill K
Old 06-12-2009, 05:34 AM   #7
Randy Magee's Avatar
Bill K
My thoughts exactly! I use an anti-seize compound on the threads after I drain the tank and reinsert... I've never waited for the tank to completely dry out... I can't see how that would help, after all it is a water tank.
Randy Magee is offline   Reply With Quote
Old 06-12-2009, 06:06 AM   #8
Randy,
Since it looks like you live in the south I can understand your confusion.
The water freezes and can break things up here in Ohio.
Bill K
Old 06-13-2009, 06:32 AM   #9
The little bit of water left in the water tank after draining would cause no problem even if it froze, if the tank were left full, sure it would be a problem... water left in the water lines would be another problem in freezing temps. The Surburban Water Heater Manual recommends that to winterize the tank, you close the tank off with the bypass valve, remove the anode rod and and drain the tank. You would want to replace the anode rod at this point to prevent intrusions into the tank of small rodents or insects. The only time they recommend removing the anode rod for the winter is when there is no bypass valve installed and you are introducing antifreeze into the system. In that case they recommend you remove the anode rod and replace it with a 3/4 " plug as the antifreeze has an adverse reaction on the anode rod. I would think rodents making a nest in the heater over the winter would cause many more problems than a few drops of water left in a drained tank.
Old 06-13-2009, 12:06 PM   #10
Steve Outlaw's Avatar
Trailer: Oliver Legacy Elite II
Mississippi
Randy,
Bill K
Anything (rusting, corrosion, etc.) that could/would happen to the threads over the winter would most likely happen anyway during the few days the threads are exposed to the atmosphere waiting on the interior of the tank to dry. This is an iron fitting and it will rust in a matter of hours. Water only expands 10% when it freezes (even in Ohio) so the little bit left in the tank won't "break" anything...
Steve and Tali - Dogs: Reacher and Lucy and our beloved Storm and Maggie (waiting at the Rainbow Bridge)
2017 Silverado High Country 2500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Can I run my Hot Water Heater Karalyn Plumbing | Systems and Fixtures 8 06-22-2009 10:53 AM
Problem replacing the water heater..... FredericL Problem Solving | Owners Helping Owners 2 04-10-2009 12:15 AM
Water Heater Q Eric & Tam Problem Solving | Owners Helping Owners 3 06-19-2007 07:00 PM
Hot Water Heater - Rusty Water terryw Problem Solving | Owners Helping Owners 9 07-15-2006 08:33 PM
Hot water Heater Legacy Posts Care and Feeding of Molded Fiberglass Trailers 7 06-30-2003 02:14 PM
