Replacing water reservoir on 84 Bigfoot - Fiberglass RV
Old 12-13-2017, 10:40 AM   #1
Trailer: Bigfoot 17
Quebec
Has anyone got leads on where to purchase a new one?
mykah is offline   Reply With Quote
Old 12-13-2017, 10:48 AM   #2
Trailer: Bigfoot 17
Quebec
Here is our original reservoir ! Ew.
Old 12-13-2017, 10:52 AM   #3
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
Do a google search for "plastic water tank for RV". You will find plenty of options.
Alex Adams is online now   Reply With Quote
Old 12-13-2017, 10:54 AM   #4
David Tilston's Avatar
Erika, I can see that you have a large amount of mold in your tank. Is that why you are replacing it? Does it leak?
You may be better off installing a deck fitting, for cleaning. Finding a new tank that is the correct dimensions will be difficult or expensive, or both.
Old 12-13-2017, 12:25 PM   #5
rbryan's Avatar
Arkansas
What are the dimensions? Makes searching for one much easier.
Old 12-13-2017, 09:35 PM   #6
Trailer: Bigfoot 17
Quebec
Hello David, no known leaks... the mould and chemical smell has us thinking a new tank would be best ... but I'm thinking that cleaning will be the more economical option.
Old 12-13-2017, 10:47 PM   #7
Trailer: 1987 Casita 16
Illinois
I searched on google "fresh water rv tank" and I think I got mine from US plastics. It was a couple of hundred, and about 50 to ship.
EricAllyn is offline   Reply With Quote
Old 12-13-2017, 11:35 PM   #8
rbryan's Avatar
Arkansas
If cleaning (mainly bleach) doesn't get it all, I've seen an ingenious (and much less expensive - around $40) alternative to buying a new tank - installing inspection ports so you can actually get inside to scrub the tank. I think water tanks should come this way from the factory, but of course that would make them more expensive than they already are. Here's a link on how it's done:
http://goodoldrvs.ning.com/m/blogpos...gPost%3A200675
Old 12-14-2017, 12:26 AM   #9
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Erika, I agree with getting a deck plate and they're cheap. I installed a 4" one on mine (sealed with 3M 5200) that allows me to reach the total interior. I'd cut the hole and do all the cleaning before installing the deck plate for a bit more arm clearance.
Old 12-14-2017, 05:56 AM   #10
Trailer: 1979 Boler 1300 / 1991 Casita Freedom Deluxe
Maine
I once found on a site called "Polymer Plastics" (I think this was the site) and if I had saved it from my older computer I would send the link but do a search for that and it should come up. They had all size tanks.
Old 12-14-2017, 06:17 AM   #11
Maine
I have also cleaned the inside of tanks using bleach. One tank was in same condition as yours and I had it out so I rinsed as good as one can, Put 3 gal. of 50% beach/water and laid it in sun for a day.
It was amazing how clean it got just from the fumes but I turned it once in awhile.
Rinse and you still got a bleach taste but I am sure all bad, living, stuff was dead.
bigfoot
securing water reservoir in 13' Scamp Richard Davis Care and Feeding of Molded Fiberglass Trailers 19 07-05-2017 04:16 PM
External Water Reservoir - DIY Ian G. Modifications, Alterations and Updates 7 04-01-2015 04:06 PM
Replacing Grey Water Tank 1978 17 foot Boler ggdub Care and Feeding of Molded Fiberglass Trailers 2 07-19-2011 06:41 PM
Replacing Water Heater rod Karalyn Problem Solving | Owners Helping Owners 9 06-13-2009 12:06 PM
Problem replacing the water heater..... FredericL Problem Solving | Owners Helping Owners 2 04-10-2009 12:15 AM
