Replacing window seal in Scamp - Page 2 - Fiberglass RV
Old 06-09-2010, 05:31 PM   #15
Michel, Bouchard's Avatar
Trailer: Boler 1300 1973
Quebec
I Tammy, from where did you get the tinted plexi windows ?
Boler 1300 1973
Jeep Wrangler 2dr 2012
Michel, Bouchard is offline   Reply With Quote
Old 06-09-2010, 07:13 PM   #16
Trailer: 77 Boler 1300
I am in Ottawa--Plastics of Ottawa--just google a location in QC for plastic/sign manufacturer's 3/16" dark tint plexiglass; rough cut--Lexan is very costly although it doesn't scratch as much.
I just popped the old one out and they cut me a new one in 10 minutes!
I am going to use the old one as a rock guard on the front--just re-paint with Krylon paint or I may put diamond plate on it? So many ideas, so little time! Bien a vous!
TammyG is offline   Reply With Quote
Old 06-10-2010, 04:50 AM   #17
Trailer: Scamp 13 ft
Post
I would like to replace the window seal in the front window on my 13' Scamp I purchased the beading and lockstrip directly from Scamp, but i'm not sure where to start. I would like to do the project myself instead of bringing it to a dealer for replacement. Has anyone taken on the project before. Thanks
My wife and I just replaced our front and back winow seals on our 13 Scamp. Used the lock strip tool and a butter knife to pry the seal over the windows with no problem. Started on one side and worked accross. As to the lock strip it was rather easy using dish soap and the lock strip tool. Remember to silicone the main seal when it joins together. We pulled out about three inches of lock strip in this area squeezed in the silicone and pushed the lock strip back in. No leaks Yea! Watch the videos also they are helpful. We placed the lockstrip side of seal on the outside.
dseguin is offline   Reply With Quote
Old 06-10-2010, 05:40 AM   #18
Rather than using Silicone, I'd recommend using black windshield caulk. It's formulated to be used with rubber and is not affected by heat or cold, water or ice.
Old 06-10-2010, 06:22 AM   #19
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: All... I used 3M Super Weatherstrip And Gasket Adhesive (Black) to bond the ends of the window gaskets together. I also used it to fill the tiny opening at the bottom of the rear window, where the gasket had pulled apart...TaDa no more leaks!!! Google www.3m.com but I think any good auto supply store should carry it.
Some jobs are no fun at all...but very satisfying when done right.
Old 06-10-2010, 10:18 AM   #20
Raya's Avatar
Whew! Now if I can just un-do that silicone heart rate...
Old 06-09-2014, 11:13 PM   #21
Seth and Desiree's Avatar
Name: Seth & Desiree
Trailer: 1987 Scamp 13'
Originally Posted by DanPatWork View Post
Raya,
I'll be perfectly honest here and say that I hate these type of windows so much, that I replaced ours during the rebuild with a new front slider from Scamp.
Dan, are you saying that the sliding window would be easier to install than just the plexi pieces?
Also, did you install the sliding window only on the front window, or both front and rear? Thanks so much!
-seth
* Professional Photographers at Zelo Photography
* Maker of Stuff and Doer of Projects at Stuff Seth Makes
* Proud Owners of Scamptastic
Seth and Desiree is offline   Reply With Quote
Replacing the front window... Scamp 13' Matthew Lyon Problem Solving | Owners Helping Owners 31 06-23-2013 06:59 AM
Window Gasket, Window Seal, Window Molding D Shubel Problem Solving | Owners Helping Owners 9 05-16-2011 04:30 PM
Scamp (curved) front & rear window seal, Help Eddie Longest Problem Solving | Owners Helping Owners 4 02-03-2010 08:57 AM
Scamp window seal installation Oliver P Problem Solving | Owners Helping Owners 6 08-26-2009 09:53 AM
Installing new window seal or gasket on front window Sue A. Smith Problem Solving | Owners Helping Owners 3 07-30-2007 07:21 AM
