Replacing wooden lip that supports benches - Fiberglass RV
Old 09-09-2013, 04:04 PM   #1
Trailer: Scamp 13'
Maine
Hey there folks,
I'm renovating my 13' Scamp and have run into a conundrum that I could use some help with. Has anyone replaced the wooden ledges that are fiberglassed into the side of the Scamp to screw the benches in (I had to take mine out as they were rotted through)? If so, how did you support the wood so it could be fiberglassed back in? Did you glue it onto the side of the trailer first? Something else? Any help at all would be so appreciated!
Here's a picture of the current ledgeless state of things - tho' I've replaced the floor (woo hoo!) since this was taken.
mary b. is offline   Reply With Quote
Old 09-09-2013, 07:33 PM   #2
Not seeing any replies yet, let me make a suggestion. When we built our kayaks, we used wood flower mixed with epoxy ti hold the seams together. Mux the 2-part epoxy first, then add the wood flower to make a paste. You will need to support the brackets until the mix dries. It makes a good bond and it fills in any gaps or texture you will have between the bracket and the wall.
Dave Fish is online now   Reply With Quote
Old 09-09-2013, 09:27 PM   #3
neauone's Avatar
Im running into the same conundrum
Originally Posted by mary b. View Post
Hey there folks,
From what I have seen on youtube videos the ledges or anything else is fiberglassed in. In our case we would have to replace the rotted ledges with either wood or some other material than using resin and fiberglass painting the resin into the fiberglass. Give it time to dry than apply more fiberglass and resin. My entire floor seems to be rotted not to mention the ledges you speak of. Also on youtube you can see how they repair boats with fiberglass as well.
I won't be doing the replacement of the floors or ledges at this time. But I have ripped out the rat fur, and basically all I have left are the walls of the scamp. Let me know how it works out and put up some pictures.
In the meanwhile once I have a chance I will upload pictures of what I have done.
My major problem is that part of the trailer is rotted through the metal, however I think I can add a metal support using the undercarriage.
Best to you.
Guy
neauone is offline   Reply With Quote
Old 09-10-2013, 07:58 AM   #4
Trailer: Scamp 13'
Maine
Thanks for the wood flour/epoxy suggestion, Dave. What I'm wondering is how to support the brackets until the mix dries- or does it dry relatively quickly (that is, could I just hold 'em there)?
neauone, I had to replace my entire floor and was able to fiberglass it in with relative ease. It's just these ledges that are confounding me!
Old 09-17-2013, 08:53 AM   #5
stevengbass's Avatar
Trailer: 1985 Scamp
Ohio
I'll be watching this thread for sure...I need to replace my lip as well.
stevengbass is offline   Reply With Quote
Old 09-17-2013, 03:30 PM   #6
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I put resin just on the back of the wood support, and stuck it against the wall, then wedged a wood 2x2I cut to the right length between the support and the opposite wall.
After they dried, I pulled the 2x2 out, and glassed them in.
Old 09-17-2013, 03:37 PM   #7
Trailer:
Bondo makes a half-decent glue to hold wood in place before fiberglassing over it -as with all bonding work, thorough keying/sanding of existing fiberglass before trying to stick anything to it is essential, even if using epoxy.
And for keying, remember that while it looks like coarse sandpaper (say, 40 grit) keys well, it doesn't key much because it has so few points per square inch (actually, 40!). Finer paper like 80 grit actually cuts more little grooves in existing fiberglass and so makes for a better bond.
Old 09-17-2013, 03:40 PM   #8
You could cut and finish your wood pieces to fit. hot melt glue them in place. after that sets fiber glass and resin them in place. You could also use automotive bondo to glue them in place and then do the fiberglass and resin to make them perminate.
Old 10-04-2013, 08:21 AM   #9
Trailer: Scamp 13'
Maine
Thank you all for your suggestions! Thought I'd give an update. A couple of very resourceful and generous women helped me cut out two new ledges and we used a quick drying epoxy to glue these ledges to the side of the Scamp.
We pretty much sat there holding them until they were almost completely dry. At that point we put a couple of pieces of cordwood (it's stacking season here in Maine!) underneath to prop 'em up. From there it was fairly easy to tab the ledges in with fiberglass.
Window lip seal help Cubey Problem Solving | Owners Helping Owners 10 07-24-2013 06:29 AM
My totally wooden Scamp yyyyyguy Hobbies & Passions 18 02-08-2013 10:16 AM
Wooden egg ? BAMA & Pachyderm Posse General Chat 13 06-13-2012 04:42 AM
Does wall covering go on top of or BEHIND lip of benches, etc.?? Vickie B. Problem Solving | Owners Helping Owners 6 06-01-2011 07:25 PM
Curved Supports for Benches Pamela S. Problem Solving | Owners Helping Owners 10 05-04-2010 09:17 PM
