Resealing Windows On Casita 1988 - Fiberglass RV
Old 05-14-2008, 09:25 PM   #1
Trailer: 16 ft Casita
I need advice on leaky windows. I'm still deciding to have this done or attempt to do this myself.
I've talked to someone who sealed her scamp with butely tape. I'm wondering how to deal with a rivet? or whatever on the outside. I believe a square head screwdriver will unscrew the inside of the window, but not sure what to use or do I have to deal with the fastener on the outside. See picture attached.
Any help would be great. Has anyone used butly tape or resealed yourself?
I have a drain from the water tank to the outside with these fasteners and wonder how I disconnect them?
Thanks
shelley troyer is offline   Reply With Quote
Old 05-15-2008, 05:40 AM   #2
DanPatWork's Avatar
Trailer: 88 Scamp 16 ft
If those rivets go through the window and into the fiberglass hull, the only way to remove the window for re-seal will be to drill the rivet.
We drilled the heads off and then "pushed" the shaft of the rivet to the inside with a small punch or awl. I don't remember any rivets in our windows other than the door window. All of the other rivets in the windows were structural to the window frame, not attachment.
If it's possible, have someone stand by on the outside (to play window catcher) while you remove the window frame on the inside. After you get the inside frame off, carefully pull back the inside wall covering around the window to see if those rivets go through the hull. If not, then all you should have to do is pull the window out.
Next step is clean all mounting surfaces, apply butyl tape, and then re-install. seal around the outside of window with something like flexi-seal if desired. There is a great thread on the board here about re-sealing with butyl tape, and the optional bike tube/rubber gaskets. Per Walthinsen had some great pics located in this thread here, it's allmost a tutorial.
hth
DanPatWork is offline   Reply With Quote
casita, windows
16' 1988 Casita for sale David Pirkle Classified Archives 8 07-24-2010 10:17 PM
1988 Casita $4600 Robin G Classified Archives 1 09-09-2009 05:38 AM
Resealing Windows - John Truitt Care and Feeding of Molded Fiberglass Trailers 4 04-30-2009 08:08 PM
SOLD - 1988 casita bob11105 Classified Archives 7 04-27-2009 04:36 PM
Resealing windows and other stuff Andrea in Oregon Problem Solving | Owners Helping Owners 4 02-15-2007 07:36 PM
