Rims - Fiberglass RV
Old 08-07-2015, 01:07 PM   #1
Trailer: 1985 u-haul 13 ft
Rims
We have a 13 ft 1985 u haul RV and need a rim for a spare tire The rims do not have the standard size bolts
septjan is offline   Reply With Quote
Old 08-09-2015, 05:37 PM   #2
Trailer: UHaul CT13
Iowa
Jan,
You may want to check threads over on the U-Haul Facebook site. [closed group... you have to join to participate] They've had many discussions of just this problem... unique bolt pattern/spacing and wheel offset. There's a parts cross-reference chart in the "Files" section of the site.
In theory at least, you can still get a rim from U-Haul. I get the impression that the degree of willingness to search one out for you varies a lot from one U-Haul shop to another.
Hubs can also be changed out, in order to give more wheel options.
I recently picked up a space-saver spare with a compatible bolt pattern as an emergency back-up unit...... from a used wheel & tire dealer. Offset wasn't the same, but the tire was narrow enough to fit in the U-Haul wheel-well anyway. [Note: most people frown on the space-saver spare option.]
Best of luck in the hunt.......
Gary
"You'd care less what people think of you if you knew how seldom they did." E Roosevelt
groys02 is offline   Reply With Quote
Old 08-09-2015, 07:19 PM   #3
Gary has it right. Join the Facebook group and look in the "files" section at the top of the page for all kinds of good info
New Rims Lainey Problem Solving | Owners Helping Owners 8 08-16-2007 01:40 PM
tires n rims Tom Stewart Care and Feeding of Molded Fiberglass Trailers 45 11-06-2006 03:01 PM
Has anyone tried 15X7 rims on an egg? AndyW Towing, Hitching, Axles and Running Gear 3 10-05-2006 09:41 PM
13" Tires on Rims Legacy Posts Care and Feeding of Molded Fiberglass Trailers 2 11-03-2002 04:03 PM
