ripples in ensolite - Fiberglass RV
Old 04-20-2013, 05:13 PM   #1
ripples in ensolite
I had ripples in the T-molding of the seams in my Trillium. I boiled them in water and removed the ripples. Reinserting them back into the seams has been difficult, but is possible. However, on one seam the ensolite is rippled. Has anyone else had this problem? How can I remove the ripples from the ensolite? (I tried a hairdryer, but it doesn't work.)
Thanks for any suggestions,
Tot
Tot Breher is offline   Reply With Quote
Old 04-20-2013, 05:15 PM   #2
Hi Tot, welcome to FiberglassRV. We're glad you're here
I'll leave the ensolite issue to those in the know, I've got a Rat Fur Scamp. But, I'm betting someone will be along shortly with some ideas.
Just wanted to say HI
Old 04-20-2013, 05:22 PM   #3
ripples in ensoiite
Hi, Donna,
Thanks for the welcome. It's my first post. I hope someone has a solution; if not, I'll move on to my next clean-up job. I'm getting the camper ready to sell -- regrettably. No on in my family wants to use it anymore!
Tot
Old 04-20-2013, 06:18 PM   #4
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
I'm not clear on what you mean by rippled Ensolite on the seam- has it come unglued?
Pictures would be most helpful if you've got them.
Francesca
Old 04-20-2013, 07:36 PM   #5
Hi Francesca, Here ia set of 3 Photos:
on my flickr page
http://www.flickr.com/photos/9838860...th/8667319380/
Old 04-20-2013, 07:42 PM   #6
Good pics- I see what you mean and have to say:
So THAT'S what my Ensolite looks like under the molding!
Kidding aside, I really think that's probably normal and will disappear under the molding once you put it back in. I wouldn't worry about it...
Camp on!
Francesca
Old 04-20-2013, 07:46 PM   #7
Thanks so much. I'll continue inserting the molding and see what happens. At any rate, it's a small problem so I'm not going to worry about it.
Tot
Old 04-20-2013, 07:51 PM   #8
Sounds good, Tot- and by the way, welcome to the club!
I hope you'll be posting pics of your Trillium- what year/model is it?
Francesca
Old 04-21-2013, 01:31 PM   #9
David Tilston's Avatar
Tot, I would say the ripples are from rippling in the T molding, before you took it off. On a hot day, they will probably disappear. Then when it cools off, your molding will start to ripple again. So it goes.
Old 04-21-2013, 06:20 PM   #10
So it sounds like there is no way I'm going to avoid on-going ripples?! We do our best, but sometimes there's not a solution.
Thank you for your interest and in-put.
Tot
Old 04-21-2013, 06:34 PM   #11
Hmmm...I'm rethinking my original answer...
I've never seen rippling of the T-molding so can't theorize about what might have caused yours. But if there's a concern that the rippling of the Ensolite will "transfer" to the T-molding and put you back where you started, then maybe it should be dealt with.
I think if I were doing this I'd cut the rippled part down rather than try shrink the "ripples" in place. Taking care not to cut out to the boundaries of the molding of course...
Francesca
Old 04-21-2013, 07:01 PM   #12
Your thinking of the problem coincides with David's: that the T-molding ripple caused the ensolite ripple, and that it probably will come back. I think I'll try your suggestion of cutting the ensolite back for part of the way. If that section doesn't cause more rippling in the T-molding, then I'll know I have the problem licked.
I appreciate your in-put
Tot
Old 04-22-2013, 07:32 AM   #13
The rippling in the T-molding is caused by repeated cycles of hot and cold, over years. Residual rippling in the Ensolite will not make this worse.
Old 04-22-2013, 08:44 AM   #14
This makes it sound like there is nothing more I can do to take the rippling out. (I've already removed it from the T-molding, using the boiling method). I'll just re-insert it into the track and resign myself to repeated treatments (or live with it). Francesca suggested that I cut back the ensolite, removing the ripples in it. What do you think?
Thanks,
Tot
Ensolite CSimmons Problem Solving | Owners Helping Owners 7 02-16-2013 09:47 PM
Ensolite available Cat futrell Problem Solving | Owners Helping Owners 1 11-03-2012 07:10 AM
Which ensolite Kent I Problem Solving | Owners Helping Owners 3 02-21-2012 02:36 PM
Ensolite Melinda M Problem Solving | Owners Helping Owners 6 06-24-2009 09:33 PM
Leveling Roof Ripples? V'sGlassSleeper Problem Solving | Owners Helping Owners 8 08-30-2007 03:31 PM
