Rivet Caps - Fiberglass RV
Old 09-22-2009, 08:20 PM   #1
Trailer: Casita 16 ft Spirit Deluxe
I want to replace some rivet caps (well, rivets, bases, and caps) on our Scamp. I know a couple of times I've seen an economical source for these posted on the site, but I can't find it. I tried searching on "rivet cap" and after reading through eight pages of results to no avail, I thought it might be more efficient to just ask!
I know Scamp sells a kit, but someone also referenced another source, almost buying in bulk. I hope one of the Search Masters can help find it.
Thanks!
Parker
Parker Buckley is offline   Reply With Quote
Old 09-22-2009, 08:22 PM   #2
Greg A's Avatar
Parker,
I believe this was the HINGE SNAP-CAPS® - Hinged Screw Covers source listed in the prior post.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 09-23-2009, 06:42 AM   #3
Parker,
Greg,
I don't remember them being hinged, but these look like they'll do the trick. The former owner of our Scamp smeared a bunch of caulk around all those on the top (I assumed Scamp didn't do it this way) and it's been on my list of things to clean up for a long time. I've never seen any signs of leaking, past or present, so I guess this was a preventative measure.
Thanks for your reply. My search skills are not up to the task I guess!
Parker
Old 09-23-2009, 10:58 AM   #4
Bill MacDermod's Avatar
Trailer: 1999 17 ft Casita Spirit Deluxe ('Inn EggsIsle')
(snap caps) http://www.pro-dec.com/
Love being Inneggsile
heading sloowly up the eastcoast to our next 2 month (Aug and Sept) camp hosting gig at Camden Hills State Park in Maine
Bill MacDermod is offline   Reply With Quote
Old 09-23-2009, 02:08 PM   #5
Parker
"A day late and a dollar short." Where were you yesterday. I just ordered 100 bases and caps of both sizes for $28 from Pro Dec. I should have posted to find someone to split a larger order since I have more than one trailer to do. For just a little more you get a much better deal. You don't want the hing caps you want the standard caps.
On the trailer I'm working on now I am replacing the larger cabinet rivets with S/S 10-24 pan head screws with one washer on the inside with a nyloc nut. I replaced a coupleof rivets with 3/4" screws yesterday (too long) so I ordered a box of 5/8" screws today. BTY the trailer I'm working on has encolite for the liner.
Scamp uses silicone as a sealer but I chose to use 3M marine sealant. I dab a small blob around the screw hole. Then put the plastic base half way up on the screw and apply sealant to both sides of the cap base an tighten then apply cap and wipe of excess.
I plan on using 1/8" pop rivets on the lighter applications.
FYI: I found some silicone remover in the hwd. dept. at Wally World. I bought a can but haven't had a chance to use it yet.
Good luck
Eddie
Old 09-23-2009, 02:36 PM   #6
Trailer: 87 Scamp 13 ft
Check your local ACE Hardware, 3 sizes
JOE DRISSEL is offline   Reply With Quote
Old 09-23-2009, 03:23 PM   #7
Aha! Great to hear. I no longer have one locally, but I know where to go!
Thanks,
Parker
Old 09-23-2009, 03:30 PM   #8
Parker
Eddie,
Story of my life, I guess! I'll try the Ace Hdwe source, since I only need a few. I also saw silicone remover at Lowes. I didn't feel like dropping $10 for it, no more that I have to do, but I filed it away for future reference. I have some butyl putty in a roll from the RV place that I think I'll use. I like using butyl caulking (again from RV suppliers) but most of it will dry up in the tube by the time I need another dab.
I'm not even sure I need to replace any rivets, but I figure the easiest way to clean up the caulking mess that's there is to drill out the rivet and start fresh.
Thanks for the post.
Parker
Hub caps Judith Kennedy Modifications, Alterations and Updates 10 10-17-2009 03:54 PM
Rivets, rivet caps, rivet gun BOBSMITH Care and Feeding of Molded Fiberglass Trailers 7 06-11-2008 09:24 PM
Hub Caps Found Darwin Maring Care and Feeding of Molded Fiberglass Trailers 2 08-25-2007 05:40 AM
Exterior white rivet caps 13' Scamp Patty57 Problem Solving | Owners Helping Owners 6 07-26-2007 09:23 PM
Scamp rivet button caps Chris Z General Chat 5 07-07-2006 01:03 PM
