Rivets holding curtain rod loose - Fiberglass RV
Old 07-07-2015, 06:58 AM   #1
BatDude's Avatar
Trailer: Escape
Hi all,
On our Scamp 16' (Oct 2014 new) I noticed on our last outing a few weeks ago that the rivets for the two brackets that hold the curtain rod over the window next to the table are loose.
At the moment I will let them be, but at some point I may need to pop the external button caps off and re-rivet these using a washer on the inside on top of the bracket.
Does simple silicon work to reattached the external button covers?
Tnx.
Bruce
Conservation biologist specializing in bats. Now stepping aside from paid $ bat work and just Escaping, painting and mentoring grad students
BatDude is offline   Reply With Quote
Old 07-07-2015, 07:16 AM   #2
Curtain rod rivets are 1/8" rivets, usually easy to buy locally. The caps and bases are #8. Use a little butyl tape or 3M 5200 marine sealer under the plastic base. (not silicone) The caps just snap on the bases after the rivet is installed no sealer needed for the caps.
Eddie
Old 07-07-2015, 02:55 PM   #3
Paul O.'s Avatar
Hi Bat Dude, the window curtain rivets on my Scamp are 5/32 dia. If you use 1/8 rivets, they will fit, but may not pull tight and seal properly, even if you use a sealer (which you should use anyway). Here is a link to a recent discussion of rivets:
http://www.fiberglassrv.com/forums/f...tml#post513988
1/8 and 3/16 dia. are the most common, the 5/32 is sometimes not in the "down the street" hardware store.
Old 07-07-2015, 06:52 PM   #4
A nice stainless steel screw and acorn mut will fix this as well.
A # 6 04 8 32 perhaps.
Some sealant in the hole might be good as well.
Old 07-11-2015, 03:06 PM   #5
Trailer: Perris pacer
I've used liquid nails ! ��
mexbob5150 is offline   Reply With Quote
Old 07-11-2015, 09:36 PM   #6
Gilda's Avatar
Trailer: 2011 Scamp 13'
Not everyone on this forum is a fan of the curtain rods and supports that Scamp installs at the factory. I'm having "technical" and decorating issues with mine. My 13' trailer was purchased in 2011. If your rods are coming loose it might be a good time to replace the supports and rods with something more sturdy. If only one rivet is loose I would leave things as they are. Unfortunately, standard "cafe curtain" rods and supports are usually of poor, lightweight quality. The rods included with the Scamp are too small to fit snugly in the rod support. I replaced my rods with cafe rods from Walmart (standard size). These rods have a larger circumference and have finials which keep the rod more snugly in place. I also put a length of old tent rod inside the hollow curtain rod, giving it more strength. In spite of this the curtain rods often "pop out" while on bumpy roads. Even when I secure the rods to the support with "zip-ties" they sometimes pop off.
Because I like to change out the look of my curtains it means I take the rods off and on frequently. I have to be very careful not to stress the support too much as it may result in weakened rivets and/or bent supports. I've attached some photos to show my "glamping" efforts. These are old photos and I think they show the original rods that Scamp installed.
If I were to purchase a new Scamp I would bring my own curtain rods and supports and ask Scamp to rivet them into the trailer. Some people prefer not to have curtain rods at all.
Good luck with your decision.
The Gleeful Glamper
Gilda (Jill-da)
Curtain Rod Brackets...I need suggestions Paul Richter Problem Solving | Owners Helping Owners 24 04-18-2016 05:42 AM
Slide on curtain rod brackets for mini blinds Donna D. Modifications, Alterations and Updates 2 03-29-2014 08:19 PM
Loose Scamp rivets Tom Smayda Problem Solving | Owners Helping Owners 1 06-12-2013 11:43 PM
Boler - Rivet Size? - Curtain Rod Bracket/Emblem Kurt in BC Problem Solving | Owners Helping Owners 7 10-07-2012 07:26 AM
Curtain Rod Keeps Falling kfletcher Problem Solving | Owners Helping Owners 8 07-17-2007 07:57 PM
