Road clearance on Scamp... - Fiberglass RV
Old 07-05-2012, 10:04 AM   #1
Trailer: 1976 13' scamp
Anyone tried to get more clearance under the Scamp? Mine has about 8" max under it. The fenderwells look to small to try and get much with a taller tire. Can something be done to the undercarriage of this 1976, 13 footer? Or do I live with what I have.
rpbailey is offline   Reply With Quote
Old 07-05-2012, 11:12 AM   #2
Fran L's Avatar
Name: Fran L and Dave W
Trailer: 2008 Escape 5.0
New Mexico
There are a number of options for increasing clearance in a Scamp: raising the axle, changing the axle arm direction in some cases (I don't know antything about that), trimming wheel wells if the clearance issue is just with the edges.
Once you have some space you can put larger wheels/tires on.
I've only had experience with the wheel well trimming. Our Scamp had a 1.5" lift in it from the factory but others have done 3 or so inches after the fact themselves with the help of a welder.
Some searches might help because there has been quite a bit of discussion about this over time.
Fran
Fran L is offline   Reply With Quote
Old 07-05-2012, 11:16 AM   #3
Trailer: scamp 13
first things second,,,,do you need a new axel? on one that old thats the first thing you need to check. if you do,,then you simply replace it with an axel that will give you the ground clearance you want.
Old 07-06-2012, 08:01 AM   #4
Trailer: '84 Scamp 13' & 2001 Casita 17' Spirit Deluxe
Arkansas
John is absolutely correct, you probably need a new axle if you're still using the original. If a new axle is needed, check this thread for what I did on my '85 Scamp 13 to increase ground clearance - Lifting a 13' Scamp - the basics?
Harvey is offline   Reply With Quote
Old 07-12-2012, 09:44 AM   #5
Wow, tons of info. Thanks to all. Looks like I will live with what I've got.
Scamp sink faucet - no clearance Doghaus Modifications, Alterations and Updates 10 09-26-2011 06:37 PM
Clearance J Joelson Problem Solving | Owners Helping Owners 4 07-29-2008 03:39 PM
Getting more clearance under your TT V'sGlassSleeper Problem Solving | Owners Helping Owners 9 08-30-2007 04:09 PM
Getting More Clearance rickster Care and Feeding of Molded Fiberglass Trailers 10 04-01-2006 06:53 PM
low road clearance Legacy Posts Problem Solving | Owners Helping Owners 3 07-21-2003 06:47 AM
