Rocking Horse RV - Fiberglass RV
Old 06-21-2011, 01:52 AM   #1
Pam Garlow's Avatar
Trailer: U-Haul 1985
Rocking Horse RV
I've noticed that when I tow, my trailer will 'rock' forward and back after I hit a bump. It just does it a few times and then stops. I feel it as a 'push/pull' motion. It doesn't appear to be swaying side to side, and the motion doesn't last more than a few 'rocks'. I try to balance my load with the heavies (coolers) over the axle, but now I'm wondering if I need to move them forward, to get a little more tongue weight?
I need some input from all you towing experts. Do I need to invest in a non-digital scale and check the weight on my tongue?
Old 06-21-2011, 09:32 AM   #2
Trailer: Fiber Stream
I'd try that 1st. Also, do you tow with your water tank full? The back-and-forth sloshing in a water tank might also produce this effect...
Old 06-21-2011, 03:10 PM   #3
Trailer: 1980 Burro
Good idea, but half full would slosh more than full and it could be true for the gray water tank too.
Another thing to check would be the shocks on your tow vehicle.
Andy B is offline   Reply With Quote
Old 06-21-2011, 06:42 PM   #4
Pam Garlow's Avatar
New tow vehicle, so that's not it. Water tank is usually 2/3 full when towing. It's empty now, so I'll see if I still have the problem when I take it into the RV place for some work in a few weeks.
Old 06-22-2011, 01:22 AM   #5
A short wheel base tow vehicle will give that feeling. I doubt it's really rocking forward and back more likely the rear of tow vehicle is bouncing up and down giving that forward and back sensation. Some of that is to be expected, and will be worse the shorter the wheel base of tow vehicle and the condition of the tow vehicle's rear shocks.
Old 06-23-2011, 05:40 AM   #6
Trailer: 84 16 ft Scamp
I usually tow with a diesel Blazer, a very short wheel-base vehicle. Everything was OK until we got to the Gulf Coast in Texas, when the bouncing started.
It turned out that one of the rear shocks on the Blazer had leaked and was not doing its job. A new pair of rear shocks fixed the problem.
Old 06-23-2011, 07:43 PM   #7
Pam Garlow's Avatar
My Tow Vehicle is a 2011, less than 7months old. No shock problems. I'll have to see what the trailer's tongue weight is, maybe that's the problem
Old 06-24-2011, 03:45 AM   #8
james kent's Avatar
Trailer: Boler 1984
How large is your water tank? If it's 20 gal and at the rear like mine you could be hauling about 120-150# of water which will offset your tongue weight quite a bit. Try towing with an empty tank and then fill up at the camp filling station. That might even increase your gas mileage a bit as well.
Old 06-24-2011, 06:48 AM   #9
Trailer: 13' Scamp Deluxe 2007 and 33' Wildcat MAXX TT
Iowa
Send a message via AIM to RSchleder Send a message via Yahoo to RSchleder
You may have a 2011 tow vehicle, however, if the spring/shock combination cannot handle the additional weight of the travel trailer you're in for bounce! You may be a good candidate for a set of air adjustable shocks, they work really well when you need to "beef up" the rear suspension capability.
RSchleder is offline   Reply With Quote
What do you do if the horse dies? Rick kl Jokes, Stories & Tall Tales 0 07-23-2009 12:58 PM
towing a 17foot ... swaying and rocking .... Herb P Towing, Hitching, Axles and Running Gear 36 09-04-2007 11:50 AM
The Trojan Horse Benita Jokes, Stories & Tall Tales 6 09-26-2006 12:03 AM
Did you hear about the Horse.. Legacy Posts Jokes, Stories & Tall Tales 1 09-21-2002 03:16 AM
