Rockwell American Tires with Rims - Fiberglass RV
Old 03-06-2018, 05:17 PM   #1
Trailer: 1977 Trillium 1300
Princess Auto has a sale on for the tires I need;175R13C
$100.00 for each combo
This looks like a good deal
Anyone have feedback on this tire.?
My 1977 Trillium appears to have room for 14ís which was previously a consideration.
This bargain may delay the switch up till later down the road.
Does this sound like wise move?
Thanks
Randy
Randy C in Ontario is offline   Reply With Quote
Old 03-07-2018, 10:31 AM   #2
Trailer: 2008 Casita 17 SD
Rockwell American Tires? I'm an "American", and frankly I've never heard of them. Just my 2 cents. Doesn't offer a lot of help, I know, but it sounds like some kind of "Brand X" tires. Let us know how they work and hold up for you if you do buy them.
As an aside, I would also recommend upgrading to 14" wheels if you have the room. There are many more tires available in 14" than there are in 13". Plus they would probably be available in a higher Load Range than the 13" tires offer. Little bit smoother ride as well with larger wheels.
Old 03-07-2018, 10:42 AM   #3
Sounds like some marketing department trying to capitalize on "Buy American" sentiment. Probably made in China.
Old 03-07-2018, 11:09 AM   #4
David L. C.'s Avatar
Trailer: Casita 17 Ft SD
I would consider upgrading to 14" rims and installing Goodyear Endurance tires.
David L. C. is offline   Reply With Quote
Old 03-07-2018, 11:55 AM   #5
Trailer: 13' Perris Pacer
Found this on the internet.
Products | rockwellamerican.com
Rockwell American
604 W. Main St. Azle, TX 76020
Don't tell the people of Texas that they are now part of China!
mchalewj is offline   Reply With Quote
Old 03-07-2018, 12:05 PM   #6
Trailer: Bigfoot B-17 CB
Most likely, they are made in China, but some major American tire manufacturers make "private brand" tires for retail sale. Firestone makes tires for Pep Boys and Sears. Goodyear owns Kelly Springfield and Kelly Springfield makes tires for Sears, Walmart, and I'm sure others. It's a real guess as to who made the tire. If a tire gets a bad reputation, it's easy for the manufacturer to changed the name and nothing else. Good luck!
Jack L is online now   Reply With Quote
Old 03-07-2018, 01:43 PM   #7
David Tilston's Avatar
If you do go with 14" tires, Ford Ranger rim work nice. They have a nearly 0 offset. But you may need to grind out the center a bit, which makes them difficult to balance later. Be careful though, the Rangers only came with 14" rims early on, (pre 2000?).
Old 03-07-2018, 02:58 PM   #8
ststefan's Avatar
Trailer: 1979 Boler1700
Maple Ridge, B.C.
You could possibly even go with a 15" rim with lower profile tires.
( Eg. My 185 75R14 tires are almost exactly the same height as 225 60R 15 tires.) There are tires comparison programs on the internet.
Old 03-07-2018, 04:21 PM   #9
Iowa
Good idea. Just installed a new set of endurance 14" with new rims. They are also load range D and USA made stamped on tires
jjohn is offline   Reply With Quote
Old 03-07-2018, 06:02 PM   #10
I am guessing that those are not trailer tires.
Old 03-07-2018, 06:56 PM   #11
ststefan's Avatar
Maple Ridge, B.C.
The 185 75R14 is the equivalent size of the trailer tires I have on right now. The program I was using didn't have trailer size matches so I had to find an equivalent size.
Old 03-07-2018, 06:58 PM   #12
A member of this site, who is better informed then I, has added this:
True, they would not be Special Trailer (ST) tires, but they'll still have lots of capacity.
  • An ordinary (Standard Load) 225/60R15 has a load index of 96 (1423 pounds per tire with 1.1 derating factor for trailer service)
  • An ordinary (Standard Load) P225/60R15 has a load index of 95 (1383 pounds per tire with 1.1 derating factor for trailer service)
tires
Larger tires/rims for my Bigfoot? Simon B Astin Towing, Hitching, Axles and Running Gear 4 04-16-2008 09:43 PM
tires n rims Tom Stewart Care and Feeding of Molded Fiberglass Trailers 45 11-06-2006 03:01 PM
13" Tires on Rims Legacy Posts Care and Feeding of Molded Fiberglass Trailers 2 11-03-2002 04:03 PM
Larger tires/rims for my Bigfoot? Simon B Astin Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
