Originally Posted by NCBOY
I just got this 13' Scamp with a "roof A/C" (coleman-brand)on it. This is my first fiberglass camper with a "roof A/C". I don't know much about these roof A/C, Are they reliable? I know they are expensive. Do they last long? Are they easy to replace and install ? Do they "leak" on the roof ? I have no experience about these A/C. Any advice on this topic will be appreciated, thank you to this forum.
AC is one of those things that you don’t need till you need it. It needs a AC power source. So, practically, when you dry camp you will not be using it.
In my experience, they are very reliable. I owned two “vintage” trailers: a 1992 & a 2002. Both AC were installed when the trailers were built, and worked perfectly for me.
Re leakage. You need to regularly inspect the rooftop casing. It does deteriorate from sun exposure and must be replaced. Otherwise, rain water will enter the roof around the AC. The manufacturer will give you the replacement part. A professional can replace it for very little cost. Just make sure he’s using a sealant that is compatible with fiberglass.
I have not used my AC all that much and only recently started camping in summer months. I now use the AC - not only to cool the trailer down, but to prevent smoke from wild fires from entering the cabin.
On hot days, I turn it on long enough to cool down the trailer when returning from the field. If we cook dinner inside the cabin, we use the AC to keep the cabin from getting too hot & turn it off once dinner is ready.
Personally, I do not find our AC to be particularly loud. If it is necessary to have it on at bedtime, it does no interfere with my sleep.
Regarding a ceiling fan. My 19 foot trailer did not have a ceiling fan. I upgraded to my BF 21 a couple of years ago. Had I kept the BF19, I would have installed a Fantastic or Max Fan over my sleeping area. I also would have installed a solar system.
My BF21 does have a Fantastic Fan over our rear bed. (I installed a lithium
battery right after I got the trailer). And I do love that fan. It really makes a difference in my comfort. With the lithium
battery, I can use the fan all day & all night long for several days. Personally, I prefer to use the AC only when necessary. And leave my
windows opened most of the time.
My advice:
- keep the AC
- Research 12 volt fans that you can hang over your bed & dining area
- install 12 volt outlets for the fans, your radio and mobile charging
12 volt stand alone fans are not very expensive & don’t require installation, other than well placed hooks. If you dry camp, they will be invaluable. If you hook up, they will allow you to open your
windows & turn off the AC when things cool down at night.
Best of luck
