Roof Escape Screen Handle - How Do I fix? - Fiberglass RV
Old 06-15-2013, 02:03 PM   #1
barryra's Avatar
Trailer: 1993 13 ft Scamp
The escape hatch handle assembly came apart when I was trying to take out 2 screws & re-insert a round metal piece so it would crank open & shut. Do I have to get on top of Scamp to fix?
barryra is offline   Reply With Quote
Old 06-15-2013, 05:34 PM   #2
Trailer: 2014 Escape 21, Lil Joe
Barry
You should be able to repair it from inside the trailer. If the gear box and arm is messed up try this to remove it. Remove knob or crank handle, remove the two screws, unlock the screen escape latch. (Big red pull latch.) Lift the screen and the top by hand. As you raise them the lift arm will slide to a opening in the slide track and the lift arm mechnism shoud be free. Then you can buy a new matching lift arm and gear box. You will need to match up with what you currently have.
Eddie
Pictures of your issue would help.
Old 06-15-2013, 09:19 PM   #3
barryra's Avatar
Thank you Eddie!! do you think I would need to contact Scamp for that lift arm & gear box or would a hardware shop etc have it?
Old 06-16-2013, 08:51 AM   #4
Barry
I think Scamp will only sell you a complete vent assy. You can buy the vent operators on line but you need to make sure it will fit since there are several mfg. (Jensen,Elixr) I would first go to a RV parts store and try to match up what you have. If you can't find one locally find one on line but call to verify measurements. You really need to figure out who made your escape vent.
Eddie
Jensen RV Vent Operator Metal Replacement Vent Arm motorhome with Crank and Scre | eBay
Old 06-16-2013, 06:07 PM   #5
barryra's Avatar
Holy Cow Batman I fixed it ! I just fed the long metal piece with the gears through the hole.. lined up the holes.. inserted the round tube shape metal piece & put in 2 screws.
Thanks Eddie for the replies...
escape
Anyone know how to fix a saggy roof in a Boler??? (around roof vent) idiotsniff Problem Solving | Owners Helping Owners 31 11-17-2014 06:50 AM
Protecting The Roof & Roof Vent Covers , AC, This Winter ???? John Cole Care and Feeding of Molded Fiberglass Trailers 25 01-15-2013 05:57 PM
boler saggy roof fix Vivian L Problem Solving | Owners Helping Owners 14 10-07-2012 02:18 PM
Looking for screen room or screen panels Deb & Chuck Classified Archives 0 09-19-2009 04:07 PM
Oversized roof vents Escape hatche pjanits Care and Feeding of Molded Fiberglass Trailers 1 09-23-2008 09:44 AM
