roof fan for Scamp 13 oversize vent opening - Fiberglass RV
Old 11-11-2019, 03:04 PM   #1
Trailer: 2005 Scamp 13
Illinois
I have an 05 Scamp 13. The roof vent has a 24.5" x 17" opening. I would like to install a fan but it looks like they are all made for a 14"x14" opening. Has anyone else had this problem? What are my options? Any help would be appreciated. Thanks
JPBrown is offline   Reply With Quote
Old 11-11-2019, 04:09 PM   #2
Trailer: 2010 Little Joe / 2010 2 Dr Jeep Wrangler
I donít have a scamp and Iím sure others will chime in... are you sure that opening isnít for escape hatch??
Old 11-11-2019, 04:19 PM   #3
IllAnnoy
You might be measuring the frame of the escape hatch. most of them the opening is 14X22 without the frame.
You do have choices...
1] You could keep the escape hatch and place the fan elsewhere.
2]You could remove the escape hatch and install the fan in the center of the opening, using a piece of Fiberglas sheet on each side, then place a light on each side or fill in with ratfur.
3] You could modify a fantastic fan and install it still using the escape hatch lid and frame.
I like the second option, I live in Illinois and I would be glad to give you some excellent fiberglass panel(s) to accomplish the job.
PM me to discuss details as to what I am thinking would make a professional looking mod.
Old 11-11-2019, 06:22 PM   #4
Trailer: 2014 Escape 21, Lil Joe
I would go with Floyds option 1. Leave the escape hatch as is. Mount the fan where the A/C would normally go. Most likely you don't have a supported roof but not needed for a fan. You will have a short concealed wire run from the closet unlike to the escape hatch. The center location work better for using it as a kitchen exhaust fan and if you have a bath it is also a better location.
Eddie
Old 11-11-2019, 07:13 PM   #5
IllAnnoy
Eddie
Definitely the easiest option if there is no A/C.
Old 11-11-2019, 07:38 PM   #6
Illinois
OK! All great options. I never thought of installing the fan separately. And i was concerned about running the wire to the existing "escape hatch" If I locate the fan near the closet I can use it as a chase to run the wires to the fan. Brilliant! Now any pointers on cutting the fiberglass hole in the roof. I am pretty skilled in woodworking but have never worked with fiberglass before. This forum is GREAT!!!!!
Thanks
Old 11-11-2019, 07:47 PM   #7
Multi tool with a circular blade. Have a Shop-Vac hose next to multi tool it will catch most of your fiberglass dust. It will cut the fiberglass and reflectix together if you cut from the outside in.
Eddie
Old 11-12-2019, 10:28 AM   #8
IllAnnoy
Rotozip set shallow,
Wear a dust mask.
A fine cutoff wheel works great on a 4" grinder too.
As Eddie said use a shop vac.
Installing Maxx Air Fan Mate 850 Vent Cover Over Fantastic Fan CampyTime Modifications, Alterations and Updates 7 10-10-2013 10:43 AM
Oversize propane tank Jonathan Wright Modifications, Alterations and Updates 1 02-24-2012 09:55 AM
To Roof Vent, Or Not To Roof Vent Frederick L. Simson Problem Solving | Owners Helping Owners 5 02-22-2009 05:41 PM
Replace roof vent on Scamp with fan? Conrad S. Care and Feeding of Molded Fiberglass Trailers 2 05-13-2008 06:45 PM
Roof vent and ac cord opening cover sherman Classified Archives 3 04-20-2006 05:47 AM
