Roof Rack - Fiberglass RV
Old 09-19-2015, 09:04 PM   #1
Trailer: 1974 Trillium
Roof Rack
Would anyone know if it is possible - or even a good idea - to attach some sort of rack on the roof of a Trillium trailer for a canoe or kayak? I don't believe there's enough room to put it on my vehicle's roof without bumping into the trailer.
And if it is possible, how?
Thanks.
NitKnit is offline   Reply With Quote
Old 09-19-2015, 10:51 PM   #2
I thought that might be a good idea when I had a tent trailer. Consider this. You arrive at your campsite and now the canoe is on the roof, but the launch site is way over there. So you have to back the trailer into the boat launch, unload, then go to your site and set up camp. Hopefully you have the canoe in sight or have it locked up.
And, you have to get that canoe up on the rack on top of your trailer, so you best carry a ladder.
Keep in mind that you can't really go anywhere else to paddle without dragging the trailer.
I carry a sixteen foot canoe on my Toyota RAV4 and have no problem with it making contact with the trailer. Don't know what your vehicle is, but there is probably no problem to solve and, if there is, there are better solutions than putting it atop the trailer.
Old 09-20-2015, 03:33 AM   #3
Raz
Raz's Avatar
Vermont
With out structural support, I think the Trillium roof would be damaged. A good roof rack on the tow vehicle is the safer route. My canoe is 16'. Raz
Old 09-20-2015, 07:31 AM   #4
farmboy's Avatar
Trailer: Trillium Jubilee
Nova Scotia
Someone in years gone by had mounted a rack of some kind on the roof of our Jubilee. Why oh why would a person put a hole in the roof of a fiberglass trailer. It resulted in a couple (of the 5) holes leaking over the years, resulting in having to replace the countertop, backsplash and the upright shelving units due to swelling and rot from water leaking in. I pulled the kitchen window and replaced the plywood structure as well. All five holes have been permanently cleaned up and repaired with silicone.
farmboy is offline   Reply With Quote
Old 09-20-2015, 10:01 AM   #5
Oh, thank you all so much. Especially Glen Baglo...never thought of that. I have a 4-door jeep, so if all your SUVs can take it, then she can too. When I was shopping for a trailer, I looked at a Boler with a new front window because the owners canoe or kayak slammed into it while on their tow vehicle, so I had that image in my head.
Thanks again, all. I will endeavour to obtain a rack for my jeep instead.
Old 09-20-2015, 10:11 AM   #6
I have the canoe tied on so that there is at least a foot of space between the canoe and trailer. Where you could get into trouble is when you have two canoes tied side-by-side and you are turning.
Old 09-20-2015, 10:15 AM   #7
Originally Posted by farmboy View Post
.....All five holes have been permanently cleaned up and repaired with silicone.
ACCCCK! Keep a close eye on your repairs. You will have problems/issues sooner or later (which really means sooner than later).
Old 09-20-2015, 10:17 AM   #8
Run the rack to the front.
Old 09-20-2015, 12:24 PM   #9
farmboy's Avatar
Nova Scotia
I guess I should elaborate. I removed the white rubber roof gunk he had slathered on the holes, shot some clear silicone adhesive on top and from the ceiling side behind the insulation, and capped each hole on top with a low profile domed plastic plug (button?). I don't foresee any problems... what is your experience. Any advice welcome.
Removing Roof Rack and Patching Screw Holes in the Roof Roger M Modifications, Alterations and Updates 4 02-08-2012 10:40 AM
Vintage roof rack wanted Brian Tin Classified Archives 0 05-07-2011 12:50 AM
Roof Rack attached to Frame jarrett beatty Modifications, Alterations and Updates 3 07-14-2010 12:34 PM
roof rack Gene B Problem Solving | Owners Helping Owners 26 03-15-2009 06:42 PM
Roof Rack LeBoutillier Modifications, Alterations and Updates 18 02-19-2006 04:17 PM
