Roof sagging - Fiberglass RV
Old 05-19-2011, 10:26 AM   #1
Camilla's Avatar
Trailer: 73 Playpac
Kentucky
Roof sagging
I just got a new to me Playpac yesterday and I need helppppp. The roof has a very bad sag (could even be sagging up to 3" in the middle of the sag). The sag is about 2 foot long anyway.
There are plenty more things to do but the condition in this one is 100 times better than in my old one I had years ago. I finally gave up on that one and sold it because it was just too much for me.
Playpac is squared with a flat roof.
Thanks!
Camilla is offline   Reply With Quote
Old 05-19-2011, 04:07 PM   #2
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Thanks!
Hi, Camilla-
Can you post a picture?
It's hard to visualize the sag you're talking about...
I don't think fiberglass stretches, per se. I think there ought to be just a bit of a "rounding" of your roof.
Is it possible it can be "popped" back out, like a dent???
Francesca
Old 05-19-2011, 05:04 PM   #3
Camilla's Avatar
Trailer: 73 Playpac
Kentucky
I'll try to get a photo tomorrow thanks. The dip up there could probably hold a few gallons of water!
Old 05-20-2011, 03:00 PM   #4
Roy in TO's Avatar
There is a difference between stretching and sagging. Even steel bridges sag.
Old 05-20-2011, 06:17 PM   #5
But-
Doesn't one side of a steel I-beam (or whatever) have to stretch for that to happen?
I think steel is more malleable than fiberglass...
I'm only suggesting to Camilla that the roof may be "pooched" in, and might be popped out again.
Francesca
Old 05-20-2011, 08:19 PM   #6
Trailer: 1985 16 ft Scamp
Ohio
Hi, Camilla-
Francesca
Hi Francesca
My 72-73 PlaPac had an outer and inner wall in except around the door and windows. I saw one other member that had a similar problem and his solution was reinforcement bars on the top.
BigMike is offline   Reply With Quote
Old 05-21-2011, 07:39 AM   #7
Camilla's Avatar
Trailer: 73 Playpac
Kentucky
Mike do you have a post of photos or anything of that?? Thanks
Old 05-21-2011, 11:24 AM   #8
Ohio
Hi Camilla
I did a search and I could not find the photo. It was a member here, I know that for sure. I think he screwed two 2X4's lengthwise along the top and then fiberglassed them in. He did some cosmetic cuts at the front and the back of the 2X4's and when he was finished, it looked really good. If one were not familiar with that particular unit, one might have thought it was original.
Michael
Old 05-21-2011, 05:57 PM   #9
You could fix it on the exterior, ala Fiberstream. here's a picture of Frederick's Fiberstream roof: Roof Sagging On Our Bigfoot TT ???? You may want to read the entire topic since it's about a sagging roof.
Old 05-22-2011, 06:04 AM   #10
Camilla's Avatar
Trailer: 73 Playpac
Kentucky
Thanks Donna that looks like a real good solution. I guess with that I won't need any inside supports. It doesn't look like the Playpac has any cabinets or anything like many of the others that support the roof from the floor up.
Old 05-22-2011, 06:34 AM   #11
Mike Watters had an extensive collection of pictures of his PlayPac resto. Unfortunately, I can't find a link to his offsite photo album. Maybe he'll step in and provide some assistance.
Old 05-22-2011, 10:15 AM   #12
Camilla's Avatar
Trailer: 73 Playpac
Kentucky
Thanks again Donna. I knew you'd come thru for me on this. You're the best!
Old 05-22-2011, 10:51 AM   #13
Trailer: Fiber Stream
Cool
My Fiber Stream is a Second Generation design, which incorporated the roof ridge support into the mold. The original First Generation design (see post #24) had the roof molded flat (like your PlayPac) with metal stiffener bars oriented side-to-side bolted to the top through the fiberglass.
My Compact Jr. roof had a bad sag over the kitchen due to the divider wall being removed by a previous owner. Since I liked the openness of the space that way, I compensated for the missing wall by adding a 9' long 2x2" angle iron along both sides of the opening for the Pop-Top, oriented front-to-back.
Remember to put Butyl Tape along the underside of the support bar(s) you use, similar to window installations to seal the through-bolts.
Old 05-22-2011, 11:45 AM   #14
Joe N's Avatar
Trailer: none
Wyoming
I am not mike, but i think this is the trailer he is referring to http://www.fiberglassrv.com/forums/f...0-a-45912.html
Picture from the thread...
Joe N is offline   Reply With Quote
Sagging Roof, and a New Vent LukeP Problem Solving | Owners Helping Owners 10 04-21-2010 08:24 AM
Sagging Roof curtis c Problem Solving | Owners Helping Owners 0 08-04-2009 04:30 PM
sagging roof in 17' boler Dawn S Problem Solving | Owners Helping Owners 13 07-17-2009 12:20 PM
Sagging roof..... kentj Problem Solving | Owners Helping Owners 2 08-29-2007 09:52 PM
Roof Sagging On Our Bigfoot TT ???? mitch Problem Solving | Owners Helping Owners 32 05-12-2007 09:46 PM
