roofing tar on trailer roof - Fiberglass RV
Old 06-08-2016, 09:46 PM   #1
Patricia D.'s Avatar
Trailer: 1975 Ventura
Manitoba
I have a "new" 1975 Ventura trailer and want to fix the roof that has been entirely covered (thickly) with roofing tar and the roof has collapsed in several areas near the back. Any suggestions about what I can do with this?
Patricia D. is offline   Reply With Quote
Old 06-08-2016, 09:52 PM   #2
Steve Outlaw's Avatar
Trailer: Oliver Legacy Elite II
Mississippi
Are you looking to remove the tar and then repair?
Steve and Tali - Dogs: Reacher and Lucy and our beloved Storm and Maggie (waiting at the Rainbow Bridge)
2017 Silverado High Country 2500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Old 06-08-2016, 10:00 PM   #3
Manitoba
I am just exploring options. I would like to remove but depends what that entails. I just realized it could be a rubber water seal product rather than tar. It is very unevenly applied, almost clumpy in some places.
I am going to tackle the concave areas from the inside. The end goal would be a slightly rounded, even not black roof.
Thanks.
Old 06-08-2016, 11:13 PM   #4
Thanks.
Have you tried removing any of it yet? Does it peel off, can you scrape it up?
Old 06-08-2016, 11:51 PM   #5
Trailer: Bigfoot B-17 CB
If it is a rubber or acrylic product, a hot water pressure washer might work. If it is a oil base tar, kerosene might work, but you might wind up with a huge mess and a badly stained roof.
Old 06-09-2016, 12:11 AM   #6
Manitoba
I have not tried removing it yet. It is dull, very dry and hard. Not anywhere that I can see where I could try peeling. Seems quite impenetrable so heat may be the only answer.
Old 06-09-2016, 01:29 AM   #7
Gina D.'s Avatar
West Coast USA
My trailer came slathered with roofing tar, thanks to the PO who was a house builder..UGH!
I used:
Copious amounts of cola (Doesn't have to be Coke) from the $1 store and about a gallon of Goof Off.
The cola "Melts the tar. It bubbles and gets real soft. Scrape most of it off with a putty knife, then get the residual off with the Good Off.
Somewhere around here is a pic of me on the roof doing this job. It took two days to do.
Here it is! The Leocraft..is MINE .. wa ha ha!
Good luck!
Old 06-09-2016, 01:37 AM   #8
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Could this be a coating like they spray in as truck bed liners?
Old 06-09-2016, 02:02 AM   #9
Manitoba
I will post a picture soon and maybe someone can tell for sure what it is.
Old 06-09-2016, 02:04 AM   #10
Manitoba
Thanks Gina D.
I May just try a corner with the cola and see if there is a reactin.
Old 06-09-2016, 08:44 AM   #11
Trailer: 77 Scamp 13
Note to self any "clever" solution implementation that starts with "here, hold my beer, I have an idea" should be put on the back burner for a at least a couple of days to consider how bloody awful it will be to deal with that clever solution down the road!
There are pictures of a project someone did to fix a roof that had been caved in by a tree. So you can fix the fiberglass without a doubt. Might be a fair amount of work or a real "learning experience" but hey the roof is already messed up, the worst that can happen is you make it worse instead of better? It is already broken!
Old 06-11-2016, 12:16 PM   #12
Manitoba
Confused about the roof
I used coke on a small patch and it is a very sunny day so I was able to scrape away about a 3" square to see what happens. Underneath appears to be wood. I was expecting a layer of fiberglass? Is this how the Ventura is supposed to be?
Old 06-11-2016, 12:51 PM   #13
Manitoba
Nevermind
Oops, further scraping revealed fiberglass under the tar residue. It is in pretty rough shape though, hence the tar obviously. This is going to be a huge job.
Roofing Tar? Really? cannibal53 Problem Solving | Owners Helping Owners 16 01-01-2013 08:53 PM
Want "tar tar" sauce with that? glamourpets Towing, Hitching, Axles and Running Gear 4 10-14-2012 05:15 PM
Tar on Scamp russelld Care and Feeding of Molded Fiberglass Trailers 9 06-12-2012 05:11 PM
Anyone know what to use to remove black tar from roof? Tim Wood Problem Solving | Owners Helping Owners 12 10-31-2008 09:06 AM
Removing road tar and other stuff ted saxton Care and Feeding of Molded Fiberglass Trailers 6 03-28-2008 10:37 PM
