rubber line vs metal line - Fiberglass RV
Old 07-08-2015, 05:10 PM   #1
We are trying to renovate a '75 Scamp that was basically gutted by a previous owner. Our Scamp has a rubber line/trim that goes around the middle of the trailer. We think this was put there by the previous owner (the said "gut-ee") because in pictures of other people's Scamps there is a metal line (trim?) that goes around the outside of the trailer. Does anyone have any idea about the 75 Scamp model's midline trim? Is it supposed to be metal? Does it hold the top and bottom together somehow? (Any idea why someone would change it?) Any ideas welcome! We're new to renovating fiberglass...
Thanks!
CarmichaelBee is offline   Reply With Quote
Old 07-08-2015, 05:51 PM   #2
Paul O.'s Avatar
Trailer: '04 Scamp 19D, TV:Tacoma 4.0L 4door, SB
You are talking about the so called belly band. It does not hold the two halves together. They are connected by fiberglass on the inside, after they are aligned and clamped together with a number of spring clamps. Mine, like all Scamps that I have seen, has an aluminum extrusion trim, held in place by small (1/8 dia.) pop rivets. Anything will work, as long as it looks good and stays in place. The one who gutted it before you, the gut-tor, probably looked for something that would not require any tooling or fixtures to make the corner bends, so he used rubber. That is my guess.
Old 07-08-2015, 06:15 PM   #3
Or he used rubber because he thought it would stop the leak. I hear its rare to have a leak on the belly area, but not unheard of, so its not likely to be the reason but still is a slim possibility.
Old 07-08-2015, 10:50 PM   #4
Thanks to both of you! There is a leak. We haven't found the source yet. It could quite likely still be the windows that don't seem to close and seal properly. It could also be something that the previous owner also tried to plug by changing the belly band. (Luckily, right now it's not the rainy season.) Thanks for your insight -- I'm sure we'll have more questions!
TRILL OUTSIDE METAL VENTS georgia g Problem Solving | Owners Helping Owners 2 03-04-2009 10:12 AM
Scamp Trailer upper cabinet metal supports... Lynn L Problem Solving | Owners Helping Owners 6 06-29-2008 10:20 AM
OEM metal roof vents Scott S. General Chat 3 06-25-2008 06:00 PM
Colour Inside Metal Boler Logo? Andrew D Problem Solving | Owners Helping Owners 2 06-20-2008 07:32 PM
Drilling stainless steel sheet metal? Tom Myers Problem Solving | Owners Helping Owners 8 11-02-2007 08:13 AM
