Old 06-07-2012, 12:58 PM   #1
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Run AC with solar panel?????
Could you run a 8 amp AC using a 100 watt solar panel plus a battery?
100 watt solar panel puts out 8.3 amps.
Old 06-07-2012, 01:13 PM   #2
cpaharley2008's Avatar
Trailer: First edition 2014 21' Escape BlackJack pulled by Dodge Ram Hemi or FJ Cruiser
that would be 1000 watts/12v or 83 amp hours, you would need 10 panels and a battery bank of at least 250 ah!! unless I'm calculating wrong
Old 06-07-2012, 01:30 PM   #3
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
This is what I used Volts Watts Amps Converter Tool Calculator
12 volts
100 watts
8.3 amps
Old 06-07-2012, 01:54 PM   #4
8 amp x 120 volts=960 watts/12v will be 83 amps in 12v
Old 06-07-2012, 02:05 PM   #5
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
I had a brain freeze.
AC on 120 volt not 12 volt
So I would need a 1000 watt solar panel to run the AC. If I had 100% sun on the panel. But I would need 2000 watt solar panel to start the AC.
This idea is OUT.
Old 06-07-2012, 02:12 PM   #6
jen b's Avatar
Trailer: 1980 13 ft. burro
If I understand correctly if you're going 100% solar, here's your best bet for air conditioning.
jen b is offline   Reply With Quote
Old 06-07-2012, 02:31 PM   #7
Thomas G.'s Avatar
Look at it this way - 2000 watts of solar panels provides a heck of a lot of shade.
Old 06-07-2012, 02:49 PM   #8
I invested in a 12v cooler fan that uses ice to cool the interior down when I had an rv that did not have a/c, works pretty good for about 2-3 hours and then you need more ice-but it maybe enough to allow you to fall asleep. here is one
Amazon.com: 12 Volt 12v Portable Air Conditioner for Ice Cooler Chest: Automotive
This should work fine with a single solar panel.
Old 06-07-2012, 02:50 PM   #9
Or a Fantastic Fan it would give you more bang for the buck!
Old 06-07-2012, 02:53 PM   #10
US
I thought paul and sherry do this for their pet while away. I thought I read that on their blog.
Old 06-07-2012, 03:40 PM   #11
Trailer: 77 Scamp 13
One thing I have been wondering about cooling since we have no AC and do not plan to hack one into an old scamp that was not designed for it. Too lazy to re-engineer I guess.
What is the air temp under the camper? Is it cooler than what would come throught the windows? Could a roof vent fan or a floor mounted fan pull that air in if there was a floor vent?
Those of us who own dogs know that they tend to go to ground under the camper if possible when it's hot. I seem to recall that even the temp under the eaves of a house was cooler than in the house and was the basis for some sort of green cooling system.
Everyone at Amazon gives that cooler fan thing 1 star, for the dog I think I would just put a bucket of ice water down, area of floor near bucket stays cooler and dog can get drink of cold water. 2fer.
Old 06-08-2012, 12:40 PM   #12
Greg H's Avatar
Trailer: 72 Boler American
Indiana
Sure it would be cooler under the trailer, until you sucked up all of the cool air and then it would be hot again.
Old 06-08-2012, 02:28 PM   #13
Trailer: FunFinder
Yeah, no kidding ! Considering my solar panel is not quite 3 sq ft and it's only a whopping 13 watts ( 1 amp ).
geo
gmw photos is offline   Reply With Quote
Old 06-08-2012, 03:00 PM   #14
If your going to be on power then a cheap small light portable ac does the job without any hacking. The PO of my trailer gave me one for the rear window that he made a little wooden holder for that went over the back window ledge and it worked really well - pretty easy to set up as well but hated packing it around in the back of the car when not using though.... havent actually bothered bring it along since installing the Fantastic Fan.
solar, solar panel
Wanted: Solar panel Roger Kimble Parts: Buy | Sell | Trade 4 11-05-2011 02:01 PM
Solar Panel upgrade shane n Modifications, Alterations and Updates 6 01-03-2011 02:28 PM
Replacing a solar panel Davie B Problem Solving -- Owners Helping Owners 13 10-27-2010 06:38 AM
solar panel Judith Kennedy Problem Solving -- Owners Helping Owners 2 10-29-2009 11:30 AM
solar panel help Maggie Problem Solving -- Owners Helping Owners 9 07-18-2006 04:38 PM
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Close [X]
