run away brake thingy - Fiberglass RV
Old 09-29-2013, 05:07 PM   #1
Trailer: bigfoot
Saskatchewan
Ok, I'm still new at this... I call it the run away brake thingy, I'm sure there's a technical term for it but it's the line I hook on when I'm towing.
So I was parking our Bigfoot for the winter, I'd already taken the battery out, and when I was jacking it up off the hitch I caught the line somehow and it snapped out.... My newby question is can I just plug it back in to the controller or is there more to it?
On another note I noticed (halfway there) that the brake controller inside the car was not on, does this need the camper battery to operate?
Thanks!
spartacus is offline   Reply With Quote
Old 09-29-2013, 05:15 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I'm assuming you mean the break away switch
Yes, you should be able to push the pin back into the breakaway switch
No, the brakes are powered off the tow vehicle, unless the break away switch is activated, then the brakes operate off the camper battery.
Old 09-29-2013, 05:16 PM   #3
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Just plug it back in, you will be fine. When you step on the brake does the red light come on?
If it does its working, if not its in the controller/ wiring. If its fused check it.
Old 10-05-2013, 09:16 PM   #4
Trailer: bigfoot
Saskatchewan
Thanks! I was worried I'd have to replace the break away switch.
Old 10-05-2013, 09:39 PM   #5
Glad you figured it out. BUT, in the grand scheme of things spending less than $20 for a safety item ... that's cheap compared to what could happen if you didn't have it when you needed it. SAFETY FIRST!
Under Bed Storage with Pedestal Thingy in the way. D Davis Modifications, Alterations and Updates 16 07-12-2013 09:48 PM
Leo Craft Whimsical Thingy Gina D. Modifications, Alterations and Updates 17 12-12-2012 08:40 PM
Stuff thingy around windows Camilla Care and Feeding of Molded Fiberglass Trailers 8 12-27-2011 08:04 PM
Need burner top thingy ronsmith100 Problem Solving | Owners Helping Owners 3 04-16-2009 06:20 PM
What's this thingy? Lizbeth Problem Solving | Owners Helping Owners 17 08-26-2006 07:07 AM
