Running my frig - Fiberglass RV
Old 09-30-2015, 07:05 PM   #1
Trailer: Escape 2017, 17B
Running my frig
Hi, I am traveling with my Boler 1300. The fridge runs on shore power or 12v. Can anyone tell me how to run it on 12v? I have no idea as I have never done this. I have an inverter in my truck but......help please. I would like to run it on 12v while towing, shore power when camped. Thanks
Christian in FL is offline   Reply With Quote
Old 10-01-2015, 08:44 AM   #2
Ohio
Depending on the model, it should have a switch to change it from 110v to 12v. Mine is located in the outside access panel. The make and model of the frige would be of great help.
cmartin748 is offline   Reply With Quote
Old 10-01-2015, 10:12 AM   #3
Lisa, it depends on what the size of the charge line from your tow vehicle as to how well towing while on 12V works or does not & the age of your fridge. If its a an older fridge the 12V function takes a lot of power. Many have found that their tow vehicles can not keep up to the drain the fridge puts on the battery. In other words you can arrive at destination with a very depleted or dead trailer battery and a warm fridge. What ever you do, don't park someplace and leave the trailer attached with the 12v running on the fridge..... not only will your trailer battery be dead so will your vehicles battery if you do not have the charge line on the vehicle set up to stop working when the vehicle is shut off - many vehicles do not have that feature.
Putting a frozen jug of water or a freezer pack in the fridge while underway and do not open the fridge while traveling works well. Have have traveled for some pretty long hot days using that approach. Works fine - just put the freezer packs right beside the most perishable items - milk, meat etc.
Old 10-01-2015, 12:10 PM   #4
Cmartin, my fridge does have those switches. My question regards how to supply 12v power while towing. Carol, I think your suggestion of adding cold packs/ice is how I will go, given that I do not have a way to monitor my TV battery until it is dead. Thanks for saving me from another problem.
Old 10-01-2015, 12:28 PM   #5
Trailer: Class A Motorhome
The usual manner is to:
Using a 7 pin, flat blade, RV connector on your TV, route a #10 stranded wire from your vehicles battery, via a fuse or circuit breaker, to the charging line pin, here's a pin layout for a 7 pin connector:
http://www.countrytrailer.com/uploads/7wayplug.pdf
Then use the same size wire on the trailer side to connect to the coach battery and to the refrigerator.
As mentioned, anything less can/will result in the refrigerator sucking down the coach battery while you are under way. The addition of an RV isolation solenoid under the hood, in the charging line will prevent the refrigerator drawing from the TV's battery when parked.
Old 10-01-2015, 12:44 PM   #6
I don't know what kind of refrigerator you have, but I have a Norcold DE704 and it automatically switches between 12 and 120 volts.
The 12 volts runs an oscillator that goes through the transformer to produce 22 - 24 Volts ac for the swing compressor. The same transformer converts the 120 to 22 - 24 volts on shore power.
My Norcold consumes about 40 watts of power from either source ~3.7 amps when running the compressor on DC and about .35 amps on A/C.
Since the reefer runs about 50% of the time that would average around 20 watts / hour or 2 amp hours on battery.
My hope is to one day have solar panels that would produce enough power to take care of this and the LED lights as well.
As an aside for Lisa ---- Did you want the last long cushion that I forgot to put out when you were last here if you swing by mobile?
Frig and heater jet size question for better cooling of frig and heating of water. Kevin K Problem Solving | Owners Helping Owners 17 02-27-2014 07:56 PM
Frig. Temp. Kevin K Problem Solving | Owners Helping Owners 5 08-22-2008 05:08 PM
wiring a switch for the frig fan Brenda Ferrell Problem Solving | Owners Helping Owners 6 07-03-2008 04:18 PM
Propane Frig Kevin K General Chat 5 04-29-2008 09:37 PM
Wanted RM211 Frig Parts Lizbeth Classified Archives 12 02-16-2006 11:30 PM
