Rust on Parkliner - Fiberglass RV
Old 08-26-2016, 09:28 AM   #1
Trailer: ParkLiner
Virginia
Rust on Parkliner
I was just washing my Parkliner and noticed some rust. Thought I would see if other people have had the same problems and how they fixed it.
1) Rust on hinges. I know this has been mentioned before. What is the easy solution?
2) Rusty screws on windows. Some screws are fine and some are rusty.
3) I have 2 propane tanks. There is a lot of rust where the tanks sit on the metal frame. Once I get it cleaned up, how do I prevent it from happening again?
Thanks
Huck is online now   Reply With Quote
Old 08-26-2016, 12:10 PM   #2
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
rust is inevitable on any ferrous metal.
You can treat the rusty spots with Naval Jelly, after brushing or sanding off any loose rust. wear gloves, dab on the naval jelly, let soak for 5 - 10 min. rinse off with clean water. dry thoroughly, then paint with a rust inhibitor paint.
Old 08-26-2016, 12:24 PM   #3
Trailer: ParkLiner
Virginia
I got a message from Tom at parkliner. He said to replace door washers with stainless steel washers. He also suggested cutting an inner tube to fit the propane tank rack after cleaning and repainting. No one else has reported a problem with rusted window screws, but he said just replace with stainless.
I have owned the trailer since Jan 2014. Rust isn't real bad, but needs to be cleaned up.
Old 11-21-2016, 07:49 PM   #4
Raz
Raz's Avatar
Vermont
A discussion about the hinges.
Parkliner hinges rusting!
Raz is online now   Reply With Quote
Old 11-21-2016, 09:52 PM   #5
Trailer: None
None
They make black plastic flexible conduit for protecting cables .
It has a split down it one side It fits perfectly on the metal lip on the bottom of the propane tank . It stops the metal to metal rubbing of the tank with the frame . The tubing is really cheap , holds up to sun and cold weather and it is easy to apply.
steve dunham is online now   Reply With Quote
Old 11-22-2016, 02:31 PM   #6
Raz
Raz's Avatar
Vermont
Good idea. A piece of rubber will just trap moisture, causing more rust. Steve, perhaps you'll get a consulting fee if Parkliner adopts your idea.
Old 11-22-2016, 02:53 PM   #7
This is my propane tanks tray after eight years. I have no plans to do anything. If in twenty years it needs replacement, I will replace it.
Old 11-22-2016, 03:31 PM   #8
Trailer: 2008 Casita 17 SD
There's no excuse for having rusting fasteners, hinges, screws, etc. other than the fact that they were not of good quality to begin with. I have owned several trailers and have had several boats moored year around in salt water, and I have never had those problems. Also, that's not the kind of answer I would expect from a guy who makes and sells trailers for his livelihood in telling you to replace them. Why didn't they just use decent quality ones to begin with when they built it.
Old 11-22-2016, 09:10 PM   #9
Trailer: None
None
Most fasteners are imported and the quality varies all over the map
I have installed hardware where it started rusting in 30 days and others that looked brand new after 3 years. Both were from the same supplier , cost the same and met the same specs.
There is a ton of crap Chinese stainless steel on the market also.
I've installed bolts that were supposed to be grade 8 yet the bolt heads twisted off.
I am not defending Parkliner but it may not be entirely their fault.
Americans want things cheap and China is willing to comply
Old 11-23-2016, 04:28 AM   #10
Raz
Raz's Avatar
Vermont
Go to any hardware store and you will most likely find Midwest fasteners. Lots of little bins. My local hardware store likes it because they don't have to stock the bins, a fellow shows up from time to time and does it for them. Expensive hardware. A little cheaper by the box. On the box it says packaged in the U.S. with parts from one or more of the following countries: Canada, China, Germany, India, Taiwan, Thailand, and U.S.A.
As I recall, the Parkliner hinge is made by them using a Kobalt universal bought at Lowes. I don't know where that's made but i doubt it's made to be out in the weather.
parkliner
Rust, Rust Everywhere! Rick Harmer Problem Solving | Owners Helping Owners 10 09-20-2009 10:37 PM
water rust stain Dorie Care and Feeding of Molded Fiberglass Trailers 23 09-16-2009 03:46 PM
rust removal John Perry Problem Solving | Owners Helping Owners 11 10-30-2006 08:01 PM
Rust Legacy Posts Care and Feeding of Molded Fiberglass Trailers 6 02-27-2003 07:36 PM
Rust on Trailer Legacy Posts Problem Solving | Owners Helping Owners 2 11-01-2002 02:26 PM
» Virginia Campgrounds
