Rust Sargeant ????? - Fiberglass RV
Old 06-03-2017, 02:44 PM   #1
Rust Sargeant ?????
anybody heard of this stuff ?? Availabilty ???
sure sounds like something a lot of us with 20 year old TTs could use...
found by accident....don't know nuttin' about it
Old 06-03-2017, 03:19 PM   #2
Trailer: '95 17ft Bigfoot
There are a number of these products on the market. I have used them for at least 30 years and found them to be good. However if your frame is rusted bad enough to make it unsafe, coating it with a rust converter won't make it any stronger. It does what is advertised. I had a 42ft fish boat and never would think of painting any rusty steel surface without coating it with a rust converter first. It only works on rusted steel not new or where it was ground down clean.
The product I used was called Rust Not. there are others. In your case Canadian Tire or Lordco would have it.
stillwater is offline   Reply With Quote
Old 06-03-2017, 07:41 PM   #3
Paul O.'s Avatar
I have had a small bottle of this for many, many years and used occasionally to salvage rusty parts. It never goes bad it seems. As he showed in the video, it needs rust to cure and bond to the surface. Called DURO EXTEND, made by Loctite Co.
Old 06-05-2017, 11:44 PM   #4
Jan Dyke's Avatar
Trailer: boler
when I worked in the auto re finishing trade 30 years ago we used a product called Rust Mort. It turns rust into ceramic oxide. It only converts rust
Jan
Jan Dyke is offline   Reply With Quote
Old 06-09-2017, 09:18 PM   #5
Denece's Avatar
Trailer: Compact II
Ospho is what I used on boat parts. There must be a bunch of brands. I believe the active ingredient was phosphoric acid. Is that what is in these other rust convertors?
Denece is offline   Reply With Quote
Old 06-10-2017, 07:39 AM   #6
Paul O.'s Avatar
Phosphoric acid is in Naval Jelly Rust Remover, which does something different. Loctite does not say what is in their Duro rust conversion, unfortunately. Officially it must be a trade secret.
Rust, Rust Everywhere! Rick Harmer Problem Solving | Owners Helping Owners 10 09-20-2009 09:37 PM
water rust stain Dorie Care and Feeding of Molded Fiberglass Trailers 23 09-16-2009 02:46 PM
rust removal John Perry Problem Solving | Owners Helping Owners 11 10-30-2006 08:01 PM
Rust Legacy Posts Care and Feeding of Molded Fiberglass Trailers 6 02-27-2003 07:36 PM
Rust on Trailer Legacy Posts Problem Solving | Owners Helping Owners 2 11-01-2002 02:26 PM
» Trailer Showcase
NO YOKE
Ron F
Scamp
barcode
