Rust streaks on fiberglass - Fiberglass RV
Old 11-03-2008, 06:39 PM   #1
Trailer: 1998 Scamp 16 ft
Hi! We are new to this forum having just brought our used 2001 Scamp home today. There are rust streaks on the side under the door holder and under the gravel guard. We need suggestions as to how we can clean these off. Have tried polishing compound, auto wax, Mr. Clean magic eraser, and comet cleanser. The heavier stuff came off but we still have some brown streaks. Can anyone give us a lead on a cleaner that will take off these streaks without hurting the gel coat?
Thanks, Ed & Gerri
Ed D is offline   Reply With Quote
Old 11-03-2008, 07:07 PM   #2
Hi Ed, welcome to FiberglassRV, we're glad you found us.
We recently had a topic going about the exact same problem. While you're waiting for some new information to appear, you may want to read the topic, just click on this title:
Rust Removal, Naval Jelly, Phosphoric Acid, Removing Rust from Fiberglass
Old 11-03-2008, 09:10 PM   #3
Alf S.'s Avatar
Thanks, Ed & Gerri
Hi: Ed... My brother had the same prob. with his '72 Boler and we used a product called Iron Out. I also use it in our water softener and toilet tanks to remove the rust stains. It's avail. in the hardware/building supply stores.
Old 11-03-2008, 10:03 PM   #4
Pete Dumbleton's Avatar
The key here is that the rust has actually penetrated the gel coat so mechanical abrasion with polish, sandpaper, hammer and chisel, etc. will only work if the gel coat is also removed.
This calls for a chemical attack on the rust, aka iron oxide, without attacking the gel coat, hence the chemical suggestions.
If they are acid-based, or you think they might be acid-based, be sure to use plenty of water so it gets washed off the frame steel...
Old 11-04-2008, 01:26 PM   #5
Tony Nowak's Avatar
Trailer: 2003 Bigfoot 17 (15B17CB), 2017 Escape 17B
Wisconsin
Hi Ed,
We had the same experience with our Scamp that set outside for three years. Rustoleum rust stripper (not rust remover) worked like magic! Can't say ennough about how effective it is, found out about it on this great board.
Tony and Darlene
Tony Nowak is offline   Reply With Quote
Old 11-06-2008, 05:01 AM   #6
Trailer: 1978 Trillium 4500 Deluxe
Hi Ed,
I used "Bar Keepers Friend" for about $2.00. You make it into a paste with warm water. Scrub it in and let it set in the sun for 5 to 7 hours. Take a stiff nylon brush and rinse 2 to 3 times. and you will be AMAZED!!!!!!!!!! I used this on restoring a 1976 13 foot scamp this past summer with excellent results. Good Luck and let me know your results!
Dave
"The Triliium King"
Dave Baston is offline   Reply With Quote
Old 11-06-2008, 09:17 AM   #7
Jake Jacobson's Avatar
Trailer: Scamp 16 ft and Trillium 4500
I used "Interlux Heavy Duty Stain Remover" http://www.boatersworld.com/product/177380029.htm
It is made for removing rust stains on gelcoat. I had some stubborn rust stains that CLR would not remove, and this stuff did the trick.
Jake Jacobson is offline   Reply With Quote
Old 11-06-2008, 12:37 PM   #8
Harry Young's Avatar
Post
I just wanted to tag another recomendation for this product too.
Harry
Old 11-08-2008, 09:36 PM   #9
I would like to thank everyone for the responses. The CLR worked pretty well, however some of the stains are still there. I'm going to try the Interlux Heavy Duty
Stain Remover next. The job may have to wait until spring. Thanks again, Ed D
Good Rust Remover for Fiberglass? Pamela S. Problem Solving | Owners Helping Owners 24 01-08-2013 07:49 PM
Streaks going down fiberglass artspe Care and Feeding of Molded Fiberglass Trailers 11 07-26-2010 09:49 PM
Removing Oxidation and Rust marks on fiberglass DavidS Problem Solving | Owners Helping Owners 8 09-04-2009 03:21 PM
Black streaks Chris Z Care and Feeding of Molded Fiberglass Trailers 5 12-07-2005 08:40 AM
Rust Legacy Posts Care and Feeding of Molded Fiberglass Trailers 6 02-27-2003 07:36 PM
» Trailer Showcase
Bigfoot
jjtotten
521
Tom H. AZ
