Rusted Brake Lines - Fiberglass RV
Old 09-19-2015, 08:54 AM   #1
Rusted Brake Lines
Chevy Silverado pickups have a history of rusted through brake lines and reviewing posts on the internet indicate they go bad around the 7th year.
I just replaced the rusted through. Rake lines on the 2007 Silverado that has less than 57,000 miles on it and driven in Virginia that has very little snow and the undercarage frequently washed. Cost over $2,400.
Have had many vintage cars through the years and presently have a 1974 VW Thing and have never experienced rusted brake lines before.
How many of you have experienced rusted through brake lines on a non GM product.
Old 09-19-2015, 10:08 AM   #2
here in the northeast it's common to be replacing brake lines. had to do it few times on an old Ford pickup that I drove for 20 years. Also replaced them on two Toyotas we own, and many other cars over the years
Old 09-19-2015, 11:14 AM   #3
I owned and own two 2003 GM truck products both for well over 7 years and never heard of this issue. Is there any kind of a recall notice? .
Old 09-19-2015, 11:54 AM   #4
Bob, There was a dismissed case from 2000 to 2005 and nothing after that. My neighbor had the problem on 2 vehicles. On one, he pressed the brake and a line blew then pressed again and the other line blew then he had only the emergency brake. Could have been a life threading moment.
I think getting a recall done doesn't happen until people have to die first.
Old 09-19-2015, 12:19 PM   #5
Is rust on autos normally an issue in California? I would be surprised if it was.
Was more than a little disappointed to have to replace the rotors & callipers on a 4 year old truck last week when I took it in for what I though was going to be a simple brake pad replacement job. 40,000 miles on the truck. Callipers & rotors where VERY rusty and I have never had to replace rotors on that age of vehicle prior but the suggestion was made by the mechanics (actually had a non partisan party go look at it before the work was done as I at first did not believe it need to be done) that is was due to A) truck spent the first 2 years of life living beside the ocean and occasionally pulling a boat (possible submerging of wheels at boat ramp?) 2) spent the next two years traveling in winter on heavily salt roads in the rockies. Still it bothered me as I have owned other vehicles with similar use history & have not had to replace the rotors when they had their first brake pad replacement
Old 09-19-2015, 12:29 PM   #6
honda03842's Avatar
Name: Norm and Ginny
My son had a Silverado with rusted brake lines and a friend had the same problem. I've never had a problem and typically own cars for 10 years and +200,000 miles. As well we've mostly lived in snow and ice regions
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-19-2015, 01:48 PM   #7
Raz
Raz's Avatar
Vermont
Here in Vt, where they brine the roads, having brake calipers "serviced" each year is common. Basically they pull the sliders and grease them. Failure to do so means the pads will stick and wear quickly. Rotors, which fill with rust, must be replaced when the pads go. I got 25k on my first Nissan before pads and rotors. A little better at 30k on a Toyota I owned. Over the years I had brake lines on 2 Hondas and a Ford ranger fail. Scary. Then there is this controversial court case. Raz
Mechanic charged with manslaughter for approving inspection of vehicle - VTDigger
Old 09-19-2015, 04:14 PM   #8
$2400 seems pretty steep for that job
Old 09-19-2015, 04:31 PM   #9
SteveV's Avatar
Trailer: Amerigo FG-16
Originally Posted by Darwin Maring View Post
Cost over $2,400.
My '04 2500 HD had the front to rear line fail due to rust. GM sells a kit with all the lines pre-bent, I bought the complete set (which are plastic coated) for around $100.00 from my local Chevy dealer.
If they get $2k + in labor for this job I need to set up shop in your area!
Not only do the brake lines fail but pay close attention to the fuel lines directly under the drivers seat......it looks like the same vendor supplied those going by the rust on mine. Pretty sad when a Southern truck that sees little to no severe winter weather has this problem.
SteveV is offline   Reply With Quote
Old 09-19-2015, 05:17 PM   #10
LOL, here's a good story on the pre-bent lines. Several years ago I bought the front pre-bent lines for my '86 GMC Jimmy that I owned at the time. Thought it was a good idea but found I couldn't get them into position. Apparently they are installed at the factory before some of the suspension components are. Ended up bending my own, they don't have to be routed exactly as from the factory. Steve is right on the fuel lines, I had to replace some of them on a couple Toyotas I owned
Old 09-19-2015, 05:30 PM   #11
Trailer: 1999 Casita 17' SD
Ohio
Rusted brake lines on silverado and other brands of trucks is old new.
At one time in the rust belt of Northern Ohio Ford pickup truck brake lines rusted out in 3 years and everyone knew it.
However with the introduction of the "New Body Style" Silverado in the second half of 2007 the brake lines are nylon coated.
The investigation linked below covered 1999-2003 but the problem went on longer.
There was a study by the NHTSA and instead of a recall they recommend inspecting the brake lines every year and deemed it an maintenance item.
Here's the real deal.
GM Avoids Recall of 2 Million Trucks for Rusty Brake Lines - Bloomberg Business
Old 09-19-2015, 06:13 PM   #12
I had the brake lines rust out on my 1999 Ram truck after 11 years of driving in Mn and Wi.
I had all the brake lines replaced for under $400. (Labor & Material)
We've had brake rotors rust so badly in one year that they needed to be relaced.
They rotors are so badly pitted from rust that they can't be turned .
Our little township in Wisconsin goes through over 100 ton of salt and sand each winter.
Old 09-19-2015, 06:39 PM   #13
Raff's Avatar
Up here in Ontario Canada rock salt is thrown all over the roads by the truckload all winter long. I take my cars to a place called Krown Rust Control and get them sprayed every October for the first 5 or 6 years I own them. I just got rid of a 12 year old Honda, 600,000 km and no rust anywhere.
Raff is offline   Reply With Quote
Old 09-20-2015, 08:18 AM   #14
Trailer: Triple E
I just replaced several of the brake lines on my 2000 GMC Sierra. It was a struggle getting them out. Coming to the conclusion that the lines were installed onto the frame before the cab was installed, I decided to buy a number of shorter lines and couplings. I also bought a double flare flaring tool, and made up my own lines, as I went along. It was a tough job. It seemed to me that brake lines should last a lot longer, as the only vehicle I have ever had to replace brake lines on was much older.
Gerry Kiernan is offline   Reply With Quote
What are these rusted posts? james.c.robertson Problem Solving | Owners Helping Owners 10 07-09-2015 09:18 PM
Rusted hardware Scamp 13 Scampergreg Problem Solving | Owners Helping Owners 4 06-18-2013 10:08 PM
Weekend trip cancelled. Rusted hitch. How to fix? Bryan L. Problem Solving | Owners Helping Owners 46 05-31-2013 09:48 PM
Rusted Screws amado_aguilar Problem Solving | Owners Helping Owners 3 07-20-2008 08:12 AM
Trillium window shade - rusted shut? WendyM Problem Solving | Owners Helping Owners 2 05-10-2006 09:37 AM
