Rusted Screws - Fiberglass RV
Old 07-17-2008, 11:08 AM   #1
I have a 1973 ECO trailer. I'm trying to remove the benches, all screws are very rusted. I've tried removal kits and drilling out with no luck. Does anyone have any other suggestions.
amado_aguilar is offline   Reply With Quote
Old 07-17-2008, 11:22 AM   #2
Trailer: 1968 Flat top Boler (serial # 92)
Grind the screw heads off, then pry the bench up--the screw should remain in the floor and can be turned out with pliers---worked for me!
sidney lewis is offline   Reply With Quote
Old 07-17-2008, 07:11 PM   #3
Trailer: 1977 Boler 13 ft
My best suggestion is to get your hands on a rotary tool example a drimel, use the small cut off wheel and score the center of the screw leaving a notch. Then twist it out with a straight screw driver. Ive used that trick with great sucess. Good luck
Johnathan Gallant is offline   Reply With Quote
Old 07-20-2008, 08:12 AM   #4
Thanks for the suggestions, I ended up going with the dremmel tool. I'm trying to replace all flooring on the trailer. Any experience with removing the shell from the frame?
What are these screws for? Ricky 4 Problem Solving | Owners Helping Owners 11 12-14-2010 12:24 PM
window re & re - what screws to use? Melinda M Problem Solving | Owners Helping Owners 4 05-22-2009 11:06 PM
screws or rivets Tim M Problem Solving | Owners Helping Owners 1 06-23-2008 12:28 PM
Replacing screws in Trillium door Kevin Falk Problem Solving | Owners Helping Owners 0 05-28-2007 09:24 PM
Trillium window shade - rusted shut? WendyM Problem Solving | Owners Helping Owners 2 05-10-2006 09:37 AM
