12-15-2014, 07:17 PM
Rusty Fridge Shelf Fix
I have some rust on the metal shelves in the '76 Trillium 1300 I am remodelling. We scrubbed them good with scouring pads, and the rust came off, but did leave some darker blemishes. No doubt this will all begin to rust again as soon as some condensation sets on it.
The metal around the outside front had some rust too, but I sanded it off, as well as the scuffed the rest of the paint, then coated it with an Appliance Epoxy. It now looks fantastic.
I would have to imagine others have had this same dilemma in their older trailers. What have you all done to correct this situation. A few ideas I have are;
1. Rough the surfaces with sandpaper, and use the appliance epoxy on them. Tough stuff, but would it stand up to the sliding of the contents for a good time.
2. Powder coat. Maybe take them to a powder coater and ask them to do them in whatever colour they are doing some time.
2. Re-chrome. Take them to a place in town that does chrome plating. They do mention redoing existing pieces of all kinds. I could maybe get my hinges done, as they have some pitting on them too.
4. Rubber coating. Anything that might work?
Looking for ideas on these, or other, options from those who may have redone their shelves, or those in the know about what to do.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
12-15-2014, 10:00 PM
When dealing with rust, after removing as much rust as possible I treat the metal with Osphoe or some other like product before painting to inhibit future rust. After cleaning I usually apply appliance paint. No primer needed and for about $5 a can you can't beat the finish. Read and follow instructions and warnings.
I recently stripped, treated and appliance painted a rusted stove cover It looks like new now.
Eddie
Amazon.com: Skyco Ospho Surface Prep Bottle 1 Qt: Sports & Outdoors
12-16-2014, 11:04 AM
I recently had a couple of small items in my home re-chromed and unless you are really good friends with the shop owner that can get a little pricey ;-)
I used some appliance paint to refinish the stove top and after a year or so it started to fail & ended up removing it all & start over .... may not have been the best of chooses in regards to which type brand of appliance paint I used though. The stuff Eddie suggests may well work better. Would be worth a try.... if it fails you can always go the powder coat route which is cheaper than re-chroming.
12-16-2014, 11:59 AM
When I redid the front pieces on the fridge with the Rust-Oleum Appliance Epoxy, I just sanded off and loose rust, and sanded the paint first. It looks great, and hopefully it holds up.
I do worry about this paint on the wire shelves, as they will take a lot of abuse, not like the sides of the appliance would take. As Carol said, it really would not hurt to try, if any other coating had to be used in the future, like powder coating, they would have to sandblast all the existing finishes off anyway.
Carol, the stuff I used warned not to use it on heating appliances like stove-tops. I think one would be better to go with a high-temperature paint.
I have never had anything chromed before, but if it is too costly, might have to forgo that. Powder coating I have had done lots, and it is not too bad.
2017 Escape 5.0 TA
12-16-2014, 12:36 PM
The stuff I used on the stove top was for high temperature use but as I said it was good for about a year then it started to peel off in spots. Not sure if it was product failure or product application failure by the party (me) who applied it.
I had two small handles re-chromed locally a couple of years ago - wanted to keep them as they were a match to a dozen or so other ones I had and thought it would be cheaper to re-chrome the two that were slightly warn than replace all the other handles that I stilled liked .... it turned out to be a bit of a push $$ wise. With your connections in the reno industry you may do better than I did on that front.
12-16-2014, 01:14 PM
Re-chroming is not something we have done in my reno business, so doubt I could find a deal. I may ask though, just to see.
I have to also redo a painted stovetop. Hard to say how the existing one was painted, but the finish seems to be wearing off easily, just from light abrasion. I think I will have to take it right back to having no paint, then redoing it will a heat-resistant paint.
2017 Escape 5.0 TA
12-16-2014, 04:41 PM
I've thought a bit about this for my own trailer. Someday (perhaps never, sigh) I'd like to Por 15 my frame. Then use the left over to fix rusty shelves and whatever else I can slap it on. Not sure what kind of finish it gives. Shiny enough? Anyone else multi use poro15?
Mark
1969 Boler (#183)
12-16-2014, 05:25 PM
I haven't heard of the Por 15, but it seems to be a tough product. I had considered a two part urethane for the frame, like Raptor from U-POL. This is a product that Robert Johans sprayed on the interior of a Trillium he rebuilt. It is tough like nails, similar to Line-X which is available only applied in shops.
The two part urethanes would definitely do great on the racks, I would have to look into the Por 15 more, but it looks good too. Another option for the shelves would be to take them to a Line-X shop, and have them hit them while spraying something else.
Definitely getting some ideas rolling here.
2017 Escape 5.0 TA
12-16-2014, 08:50 PM
I have used the Por 15 Rust Preventive Coating and I don't think it would leave a nice enough finish that I would want it on my fridge shelves. Por 15 does make a Detail Paint that comes in a spray can - that looks like stainless when applied. Not sure how it would stand up to items being dragged across it everyday though. Might want to read the technical data on it before trying.
12-16-2014, 11:01 PM
Have you ever heard of cold galvanizing? It's galvanize in a spray can and it works great. Rustoleum makes a version of this and there is another brand called ZRC. After cleaning the rust off whatever metal you want to refurbish spray it with the cold galvanize to prevent further rust and to use as a primer and then spray it with your favorite spray paint. There are metalic spray paints called " Hammered " that look pretty nice and will give your project a very proffesional looking apearance.
Lee
12-17-2014, 12:44 AM
Trailer: Casita 13
powdercoat
12-17-2014, 12:56 AM
Take the shelves out and fill the fridge with case of beer. Problem solved.
12-17-2014, 02:02 AM
I thought I was the only one that packed that way.
12-17-2014, 07:19 AM
I have used cases of this stuff over the years, back when I built electrical substations. We used it on galvanized structures whenever we drilled or cut the metal to stop the bare metal from rusting. I just wonder/worry that these paints will be tough enough for the rigours of cans, bottles and the such sliding on them a lot.
After the money I am going to have to spend on this trailer, my daughter can buy her own damn beer, but I like the way you are thinking here.
Originally Posted by Donna D.
I have wondered about this too, and how tough this Plasti Dip is for this situation. If I reuse the bike rack that was built for the trailer, I will likely have to recoat the protective rubber on the pieces the bikes hang from. Maybe kill two birds with one stone (can)?
2017 Escape 5.0 TA
12-17-2014, 07:43 AM
I suppose that sliding cans and such across refinished shelves could wear down the paint but I have always believed that every problem has a solution. What if you went to the local home building center and bought some plexiglass and cut it to fit over the various shelves. Sort of like having a piece of glass cut to go on top of a new coffee table or dresser drawer to protect the finish.
Lee
12-17-2014, 07:53 AM
That is another thought, Lee. I actually have a 4x8 sheet of 1/8" white acrylic in the garage.
2017 Escape 5.0 TA
12-17-2014, 08:13 AM
You sound like a fellow handyman. Depending on where the acrylic is installed in the Fridge you might consider drilling some holes in it for air circulation.
Lee
12-17-2014, 08:15 AM
If this is more than an ice box, you don't want to restrict air flow by using solid materials as shelves. Your refer will end up with hot and cold spots. They don't work like compressor frigs, but you know that Jim
12-17-2014, 08:31 AM
Jeepers, build me up, then knock me down. Never thought this thread would be so much of an emotional roller coaster.
But yeah, I do know room has to be left for good circulation. We always use a fan inside our fridge in our Escape, to keep temps equal throughout. I will definitely keep that in mind.
2017 Escape 5.0 TA
