RV Anti-Freeze - Page 2 - Fiberglass RV
Old 11-19-2008, 03:21 PM   #15
pjanits's Avatar
Trailer: 17 ft 1986 Burro
this guy says he drinks it all the time and there's no problem.
BTW, it's a real photo of a real person outside my office this week.
A lunch break is a lunch break!
Old 11-19-2008, 04:30 PM   #16
Raya's Avatar
Raya, I am getting a Trill 13 also. A new one from the U.S. How old is yours and where are you in the Mid Atlantic? I am originally from N.J. now living in Ohio. Thanks for the info....Lloyd I'm set now with this issue.
Hi Lloyd,
Mine is a 1976 - I'm in the Richmond, VA, area.
Congrats on your "soon to be yours" new Trillium!
Raya
Old 11-19-2008, 08:08 PM   #17
Trailer: 2009 Scamp 16 ft / 2014 Ford E-250 cargo van
What I do on my boat ( no trailer yet ) is to unhook the line from the tank at the pump then make up a hose bare on one end and a connector that fits the pump on the other end. Then depending on the pump I either prime the hose or just put it in the bottle of RV antifreeze and turn on the pump.
Then all you have to flush out in the spring is the lines.
Also be sure and bypass the hot water tank if you have one.
Bill K
PS Almost forgot I also blow out the lines first. ( Take's less antifreeze )
I guess I do a combination of the above. I blow the lines out as well as I can and then put about a gallon in the fresh water tank. Turn the pump on and flush until pink comes out. I then blow the lines out again and catch the pink stuff in a small bucket. I recover most of it til next year and the lines are not sitting with pink stuff. Oh then I drain the fresh water tank into the bucket too. End up not using much at all.
[/quote]
Old 11-19-2008, 08:38 PM   #18
Raya's Avatar
That sounds about like what we do, Bill. i.e. blow things out, but then run anti-freeze (or Vodka) through so that if there are any low spots or any areas of trapped water, they aren't going to freeze. Air of course doesn't freeze (well, unless you're in northern Minnesota There we used to use -100 anti-freeze! (the typical "pink stuff" is -50).
Old 11-20-2008, 10:40 AM   #19
Pete Dumbleton's Avatar
You'd likely be OK with the pink stuf in MN, because the temps have to go below -50F and stay there for a while to freeze something rated for -50F, presuming the egg isn't exposed to winds (which will hasten the heat transfer away from it).
Old 11-20-2008, 12:54 PM   #20
Raya's Avatar
Sorry, I might not have been clear in my post. We used to use -100 on boats, and at that it was only in the engine itself (cooling system). Our reasoning was that if there was any water trapped for some reason it might dilute the anti-freeze, thereby making it less potent. It's one thing to replace a frozen water hose, but quite another to buy a new Yanmar diesel! We did use -50 on the non-engine systems.
Old 11-20-2008, 03:57 PM   #21
Be aware that -50 RV antifreeze means BURST protects to - 50
I was reading that off of the bottle as I typed.
It is rated different that car antifreeze.
Bill K
Door Freeze Dennis McMillan Problem Solving | Owners Helping Owners 8 02-17-2010 12:21 AM
Trailer Anti-Theft Keith Williams Problem Solving | Owners Helping Owners 22 09-02-2009 01:01 PM
PEX and freeze resistance Per Walthinsen Plumbing | Systems and Fixtures 2 10-16-2006 07:05 AM
Anti-Sway bar Quint Care and Feeding of Molded Fiberglass Trailers 7 01-19-2006 04:32 PM
Anti-backflow valve Legacy Posts Plumbing | Systems and Fixtures 22 03-21-2003 09:05 PM
