RV System Monitoring Panel wiring - Fiberglass RV
Old 08-26-2017, 05:15 PM   #1
Victor Benz's Avatar
I'm trying to help a neighbor with a multi-item monitoring panel in the stove range hood. The range hood light works, the water pump works, the range hood fan works, but the single switch to show the multiple system "levels" does not show any lights. He has black water/gray water/clean water/propane levels with two battery monitors. Each has 4 lights showing level. None illuminate when the switch for "Levels" is thrown. All system fuses seem to be OK. The previous owner made some mods to the wiring. The way it was didn't work, neither did returning it to what looked like original connections.
There is no brandname on this panel.
Does anyone have a wiring schematic for such a panel?
Thanks in advance;
Vic
Victor Benz is offline   Reply With Quote
Old 08-26-2017, 06:34 PM   #2
sounds weird....
"propane levels"...???? and two battery monitors ????
pictures would be nice....year and make of trailer would help too
« Rot | We need A/C »
TireTraker Tire Monitoring System Review jeffz Modifications, Alterations and Updates 28 07-01-2016 04:55 AM
Battery monitoring system... cpaharley2008 Electrical | Charging, Systems, Solar and Generators 0 12-19-2014 12:44 PM
Replacing System Monitoring Panel And Tank Sensors mitch Care and Feeding of Molded Fiberglass Trailers 2 08-24-2010 04:32 PM
Wireless Tire Pressure Monitoring Systems Pete Dumbleton Problem Solving | Owners Helping Owners 14 11-23-2006 07:16 AM
