RV Wiring - Fiberglass RV
Old 01-04-2007, 03:59 PM   #1
Just happened to run across this site while researching something else.
http://www.dasplace.net/RVWiring/wiring.html
Old 01-04-2007, 05:28 PM   #2
Thanks for that posting this link. It looks like pretty good information.
However it does show why I have objections to the use of the term "ground".
In the discussion about AC 120/240 the term "ground" means just that, the earth. The green wire is connected to earth at some point in the shore power distribution system, usually at the power distribution box.
In the discussion about the 12 Volt DC the term "ground" means negative battery. If the RV is NOT plugged into shore power negative battery is NOT connected to the earth. In some cases but not all, if RV is plugged into shore power the negative battery terminal might be connected to earth through the converter.
As you can see it gets rather confusing.
Better terms. AC green wire = safety ground.
DC negative terminal = (-) or negative
Old 01-04-2007, 05:40 PM   #3
Brian B-P's Avatar
I agree with Bryon, although I do fall into the trap of calling the negative side of a 12V DC automotive circuit "ground". Another term which does not get confused with the safety ground is "return", as in the "supply" or "hot" (positive) and "return" (negative) sides of a circuit.
Old 01-04-2007, 05:52 PM   #4
I must admit that I too often call the negative side of a DC circuit "ground", mostly when talking amongst my career peers. Otherwise I try to avoid it.
Old 01-04-2007, 10:12 PM   #5
Ron N's Avatar
Trailer: 2007 Bigfoot 25' Rear Queen
Check this site out...
http://www.ccis.com/home/mnemeth/12volt/12volt.htm
Ron N is offline   Reply With Quote
Old 01-04-2007, 10:52 PM   #6
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft
Good site.
Old 01-05-2007, 10:31 AM   #7
As an Aircraft mechanic in the Army, we would send all the newbies out to find the bucket of "Dirt" (Ground) in the aircraft to change to freash dirt.
Old 01-05-2007, 06:50 PM   #8
james kent's Avatar
Trailer: Boler 1984
Check out our own DOCUMENT CENTRE. The 1979 Boler brochure, pages 12, 13, 14 have typical electrical system diagrams for 12v lighting, 6 way plug connections, breakaway switch and more. This information is of use to any FG trailer not just bolerites
Old 01-27-2007, 04:45 PM   #9
Denise K's Avatar
Trailer: 1972 MKP Grandesse T (made in Denmark)
Ron N, thank for posting that site!
I've been reading past posts and on-line and getting quite an education as I reqire my danish camper.
The site is a great help!
Denise K is offline   Reply With Quote
Wiring Schematic? shelley w Problem Solving | Owners Helping Owners 3 07-29-2009 09:01 AM
Wiring Questions Dave Mac Problem Solving | Owners Helping Owners 21 07-12-2007 07:12 PM
How to hookup AC wiring? Tirah Care and Feeding of Molded Fiberglass Trailers 2 06-06-2006 07:03 AM
Wiring Gauge D Shubel Problem Solving | Owners Helping Owners 9 05-09-2006 05:44 PM
DC Fridge Wiring Legacy Posts Modifications, Alterations and Updates 7 03-06-2003 11:20 AM
