S-L-O-W Sink Drain - Fiberglass RV
Old 08-21-2013, 07:56 AM   #1
S-L-O-W Sink Drain
The galley sink in our Scamp 13' drains very slowly and has since day one. My guess is it's a simple fix, yet the access below the sink is challenging at best. I'd be interested to know if anyone else has experienced this and more importantly, the solution.
morz4 is offline   Reply With Quote
Old 08-21-2013, 08:16 AM   #2
tractors1's Avatar
Trailer: Escape 21 - Felicity
Easier to check the vent first - maybe partially plugged by critters (mud dauber nest?)
Charlie Y
Charlie Y
Old 08-21-2013, 08:25 AM   #3
Trailer: 2005 13 ft Scamp / 2004 Honda Odyssey
Do you have the permanent gray water holding tank under the trailer, or do you have the portable one outside the trailer?
We had a problem with our grey water jug once. I shortened the hose and moved the tank closer to the outlet. Our hose is not sealed where it goes into the jug so it can vent.
I have been wanting a tank installed under the trailer, but have wondered how they vent. Will be interesting to read the replies you get.
Nancy
Nancy is offline   Reply With Quote
Old 08-21-2013, 08:30 AM   #4
Trailer: 2014 Escape 21
Virginia
Mike
Besides venting, your drain hose may be collapsed check out the line to the tank and make sure it is not kinked. You can also disconnect the hose at the tank input behind your converter and see how fast the water drains into an open container. There is also a trap under the sink you can check.
Eddie
Old 08-21-2013, 08:39 AM   #5
Virginia
Nancy
The tank on a 13 had two hose barbs on top that come up through the floor near the converter. The sink hooks to one and the vent hose hooks to the other. The vent hose loops up under the seat then it exits through the floor. Later modes also have a connector on the back of the tank for the shower drain if equipped. I installed a tank in my 2005 S-13.
Eddie
Old 08-21-2013, 10:45 AM   #6
carlkeigley's Avatar
NE Oklahoma
Nancy
This is how the Snoozy grey water vents......
SNOOZY FACTORY
Old 08-21-2013, 11:44 AM   #7
honda03842's Avatar
Name: Norm and Ginny
The Scamp's gray tank has a hose the comes out of the top of the gray tank that must serve as a vent and possibly an overflow.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
honda03842 is online now   Reply With Quote
Old 08-21-2013, 12:22 PM   #8
Its possible as others suggest that the pipe has a little kink in it preventing full out flow. Or someone poured something down the drain that has clogged the pipe. Disconnect the hose from the sink P trap and run a wire snake down it to see if there is any resistance. Also possible the P trap under the sink has something stuck in it - easy to take off and check.
Old 09-02-2013, 09:32 PM   #9
Yep, the drain hose was collapsed at the fitting to the holding tank. I did a quick temporary fix while Scamping this weekend. Believe I'll install a pvc elbow at that juncture to avoid the plastic drain hose collapse. Thanks, all!
Old 09-03-2013, 06:07 AM   #10
Virginia
Mike
Good to hear the feedback. Glad you found your problem.
Eddie
What's missing @ sink drain line ?? partslady9 Plumbing | Systems and Fixtures 2 02-11-2013 10:52 PM
Drain hose (sink) specs and availability? Darrell O Plumbing | Systems and Fixtures 3 09-07-2012 07:10 PM
Replace sink drain hose 13' Trillium Barrie Bochoff Problem Solving | Owners Helping Owners 5 07-20-2010 08:48 AM
Sink Faucet and Drain in 2006 Trillium & etc Nichole Adams Plumbing | Systems and Fixtures 9 09-08-2009 10:08 PM
Sink drain valve Myron Leski Modifications, Alterations and Updates 30 02-15-2006 03:30 PM
» Trailer Showcase
MyBoler
artx
Parkliner
accrete
