Sagging Boler 1700 roof - Fiberglass RV
Old 10-05-2019, 05:48 AM   #1
TN
So I sold my scamp earlier this summer and took a gutted Boler 1700 in trade. I figured it would make a good hunting camper for a couple of year till I can get around to completely renewing it. I patched up all the holes left from the PO's who had removed everything and I mean everything, pulled the frame out and made some repairs and modifications then put a new plywood floor in. That was several months ago i recognized the roof had some sag and I figured it was from no interior support so I through in a couple of 2x6 support left it for later. Well later has come and I climbed up to look at removing one of the damaged ceiling vents and replacing it with a MaxxAir and I notice the raised center of the roof was sagging more than I realized.
So here is the question, as I look closer it looks like the roof/ceiling are two layers of glass sandwiching a wood core. Can anyone confirm this?
Eric Frye is offline   Reply With Quote
Old 10-05-2019, 07:51 AM   #2
John in Michigan's Avatar
I replaced the rear roof vent in my Boler 17 a couple of months ago. While doing that the layers I saw starting at the top/outside:
- gelcoat
- fiberglass/resin mixture
- ensolite inner liner (neoprene-like rubber with white vinyl coating)
The roof, sides and bottom all seem to consist of the same single layer fiberglass shell. Ensolite lines the ceiling and walls.
My roof sags somewhat. At some point, I will attempt to counteract the sagging by first propping up the roof into the desired shape, then grinding off some of the gelcoat, then adding several layers of fiberglass and resin.
Trillium 4500 Journal
http://www.fiberglassrv.com/forums/f...nal-81345.html
Old 10-05-2019, 12:24 PM   #3
Trailer: Currently shopping
Saging roof
A good way to reinforce fiberglass that is saging is to make a tube scross it. After the roof is jacked up, lay a tube, piece of garden hose, cardboard tube or just something to be a form for a fiberglass tube across the top, saturate a piece of woven fiberglass with epoxy and lay it over the tube and let it spread out on each side of the tube. Sand and clean the old fiberglass where the new will be adhering to it. Be sure to use epoxy, not anything else. This makes a strong reinforcement and should not show up badly from the ground. You can put gel coat over the new glass if you like or paint it. It does need protection from UV.
J Ron is offline   Reply With Quote
Old 10-05-2019, 01:19 PM   #4
I have a 1978 Trillium 4500 that I rebuilt about 5 years ago and it has a single layer of Fiberglass covered with gel-coat. This was a manufacturing defect and was worse in later build dates (due to cost cutting). This is a common problem with older FG sailboat decks, especially ones with dual FG with wood sandwich construction where the wood rots after many years of use and being exposed to a humid environment. Using a half carton tube in criss-cross may not be pretty but should work with proper finishing. On a ground-up restoration it might be best to remove the top half of the body and install the support on the inside? But is a lot of work!
jokra is offline   Reply With Quote
Old 10-07-2019, 04:03 AM   #5
Saging roof
I agree putting reinforcement on inside will be much better. It will be supporting all layers but on top only the top layer. If it is much easier to do on top bolts through the tube to s strip of metal or wood would support all layers. An extra layer or fiberglass where the bolt holes will be would help. I kave not done this bolting thing before but see no reason it will not work if sealed well.
Old 10-12-2019, 06:17 PM   #6
TN
The problem with Bolers is they had to many chefs. Every factory had different processes and specs. John from the photo in your profile I believe you have B1700 from Winfield, were I have a B1700 from Earlton.
I do appreciate the ideas for correcting the sagging ceiling. At this point I'm not sure what I will do.
boler
My sagging roof fix AND exterior window trim query for my Boler clone Noah JJ Problem Solving | Owners Helping Owners 1 10-08-2019 01:57 PM
sagging roof in 17' boler Dawn S Problem Solving | Owners Helping Owners 13 07-17-2009 12:20 PM
Sagging roof..... kentj Problem Solving | Owners Helping Owners 2 08-29-2007 09:52 PM
Roof Sagging On Our Bigfoot TT ???? mitch Problem Solving | Owners Helping Owners 32 05-12-2007 09:46 PM
sagging fiberglass roof on Surfside ericmarlo Problem Solving | Owners Helping Owners 3 08-31-2006 01:35 PM
