sagging Rat Fur - Fiberglass RV
Old 09-16-2019, 09:28 AM   #1
Trailer: 85 13'Scamp Deluxe
Nevada
sagging Rat Fur
I have an older 87 Scamp, 13'er with some spots in my ceiling rat fur that are loose and sort of sagging down. Does anyone know if there is a way to inject glue through the fur to stick it back up? If so, what did you use and Thanks
John T.
Chooch is offline   Reply With Quote
Old 09-16-2019, 09:44 AM   #2
Trailer: 2014 Escape 21, Lil Joe
First let me say the rat fur will stretch if pulled on too hard. The 2" trim strips can be removed to access your sagging areas. The trim strips can be reattached with hot glue after you reglue the rat fur. As for the sagging ceiling and wall open up the area and spray 3M 90 spray glue on the back of the rat fur and reflectix wait a few minutes and press them together. Do not over saturate or the glues will show through. The 3M 90 can also reattach the reflectix to the shell if needed.
Eddie
Old 09-17-2019, 11:53 AM   #3
Nevada
Thanks
Old 09-18-2019, 07:05 AM   #4
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
I used DAP High Temperature Headliner Glue, as it holds up to the Arizona heat and does NOT bleed through like the 3M 90 does. I have also used Loctite Professional Performance contact adhesive 300 Heavy, with good results.
Good luck.
Dave & Paula
Old 09-19-2019, 04:31 AM   #5
DonnaMarie's Avatar
Trailer: 2013 Lil Snoozy
Good luck.
Dave & Paula
Great suggestion David!
DonnaMarie is offline   Reply With Quote
Old 09-25-2019, 05:51 PM   #6
starsea's Avatar
Trailer: Park Liner
South Carolina
I used Loctite 300 on mine with good results.
starsea is offline   Reply With Quote
Sagging rat fur Jiggs Problem Solving | Owners Helping Owners 2 07-18-2017 11:21 AM
Rat Fur Sagging Baj Problem Solving | Owners Helping Owners 5 05-07-2011 07:06 PM
Scamp rat fur: help andre robillard Problem Solving | Owners Helping Owners 6 04-29-2007 04:33 PM
Replacing Rat Fur peterh Care and Feeding of Molded Fiberglass Trailers 4 10-20-2006 11:50 AM
RAT FUR..CAT DOESN'T UNDERSTAND Susan Tiller General Chat 12 04-23-2006 10:12 PM
