Sagging Scamp Door - Fiberglass RV
Old 12-06-2014, 09:39 PM   #1
Idaho
Sagging Scamp Door
Hi all, a newbie here, so this may be a repeat question, but I didn't find it when I searched.
The door to my Scamp 13 is sagging, although the don't seem to have shifted.
Has anyone been down this path before?
I was think of taking the door off, redrilling the hinge holes, adding a wooden support behind it, and putting it all back together.
Thanks for all support and hints.
Cathy, Boise
CBinID is offline   Reply With Quote
Old 12-06-2014, 09:55 PM   #2
Borrego Dave's Avatar
Welcome to the group Cathy. I've seen a number of posts that talk of that problem. I'll leave the fixes for those who have done them to chime in. Some times it's just a worn out hinge to the body shell saging . It would help if you posted some pics as that really helps us out.
Old 12-06-2014, 10:53 PM   #3
Virginia
hi cathy & welcome!
does your scamp have the brace inside that goes from the upper cabinets down to the sink?
sharon_b is offline   Reply With Quote
Old 12-06-2014, 11:03 PM   #4
IllAnnoy
Before you do anything to the door.... carefully check the frame for cracks.
It may be the trailer body which has shifted. (hope not)
Check the hinge pin bolts for wear, sometimes you can just drill out the hinge and replace the 1/4" pin bolts with 5/16" stainless . That could make the hinge concentric once again if it has wallowed out.
Got Pictures?
Old 12-07-2014, 06:55 AM   #5
Trailer: 2014 Escape 21, Lil Joe
Like Floyd said an under trailer inspection is in order. Besides inspecting the metal frame at either side of the the base of the door there are pieces of plywood which is used to attach the shell (door frame) to the metal walkway frame extensions. Check these pieces of wood for security and rot. These pieces of wood more than likely have glass cloth applied over them. Hopefully hinge maintenance is all that is required.
Eddie
Old 12-07-2014, 03:57 PM   #6
Paul O.'s Avatar
Trailer: '04 Scamp 19D, TV:Tacoma 4.0L 4door, SB
The Scamp door is pretty much flush with the outside of the body shell and it should fit well into the recess. The gap on the left, right and top should be about the same width. Does it close well or do you see light when looking from inside?
Old 12-07-2014, 05:14 PM   #7
Cathy, help us help you. Update your profile to include the year of your Scamp build. And if you could post a picture or two of the door problem, that would certainly help.
Old 12-08-2014, 09:41 AM   #8
Idaho
Originally Posted by sharon_b View Post
hi cathy & welcome!
Hi Sharon, it did before we pulled the cabinets out.
Cathy
Old 12-08-2014, 09:55 AM   #9
Virginia
oh dear, that wasn't just for looks! it stops the roof from sagging & the door. I found that out here on this forum
Old 12-08-2014, 10:54 AM   #10
IllAnnoy
I bought an older Scamp with the furniture removed. I towed it 600 miles to home with a hasp holding the door closed and the shell behaving like a pillar of jello.
I had to form the shell back to its original position as I built the new interior.
The door fit fine after the rehab.
I think you may have found the problem.
Old 12-08-2014, 01:25 PM   #11
Trailer: 77 Scamp 13
Both the cabinet to counter metal brace and the closet provide supporting structure.
This thread on redoing the front floor has a picture that shows the wood brace that connects the bottom of the door frame on the hinge side to the frame. Might give you an idea of what you are looking for underneath.
Fiberglassing Floor
Scamp sells replacement hinges and hinge pins. If you decide to go that route call and ask for US Postal shipping, cheaper than web store shipping for small items.
"Pillar of jello" now there is a description of a Scamp I have never heard before. I would think if the shell is properly attached and supported there would be no need to re-drill and move the hinges. If that bottom wood piece has rotted or become detached the bottom of the door frame will continue to move and allow hinge side to sag more as time goes by.
Old 12-08-2014, 05:01 PM   #12
IllAnnoy
Fiberglassing Floor
Be sure and know which hinge set you want the design was changed a few years ago.
That sagging door... ThomKat Care and Feeding of Molded Fiberglass Trailers 19 10-19-2013 02:28 PM
Sagging Ensolite Dawn S Problem Solving | Owners Helping Owners 4 07-15-2009 01:54 PM
Door sagging? Pamela H Problem Solving | Owners Helping Owners 6 11-28-2008 03:03 PM
Sagging Trillium Door Fix Joseph Olajos Problem Solving | Owners Helping Owners 4 07-12-2007 02:36 PM
sagging door Legacy Posts Problem Solving | Owners Helping Owners 29 07-08-2003 10:39 PM
