"Sanding your GROUND" - Fiberglass RV
Old 05-30-2007, 06:10 AM   #1
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: A few nights ago I saw the left tail light LED's glowing in the dark and the trailer was not "Hooked to the Tug" ... I figure I have A BAD Ground -negative- connection!!! Power must be leaking from the Coach Battery Does any one know of a clamp that can be used rather than a screw and washer drilled into the frame...that has gone to rust !!! I would like it to be more maintainable
Alf S. North Shore of Lake Erie
Old 05-30-2007, 02:33 PM   #2
Paul and Libby Smith's Avatar
Trailer: 1994 19 ft Scamp 19 ft 5th Wheel / 2001 4wd 6cyl Silverado
Hi I use stainless steel screws and washers, from lowes or home depot.. they do real well for me..Paul Orlando fl
Paul and Libby Smith is offline   Reply With Quote
Old 05-30-2007, 03:27 PM   #3
Trailer: 94 Casita 16 ft
We just use a nut, bolt, and washer through a hole in the frame for a ground on our highway salt trucks. Works quite well for us.
Paul from NWOnt is offline   Reply With Quote
Old 05-30-2007, 08:51 PM   #4
I assume you're talking about a connection to the trailer frame. If in fact the problem is a faulty connection to the trailer frame, there has to be more than one connection to the frame. If your tail lights are mounted to the bumper it could be at that point. If they are mounted to the fiberglass then there has to a wire to negative side of DC system. It's possible, but unlikely, that there's a wire going from the light fixture to the frame.
Good luck
overcoming a "charm-ectomy", rotten floor & other issue Kelly G Problem Solving | Owners Helping Owners 5 05-22-2009 12:57 PM
SOLD - 1970 Boler on "Ebay" 10 hours/ 20 Minutes left Dave Baston Classified Archives 5 04-12-2009 10:45 AM
INFO RE Fiberglass "Travel Lite" Trailers of Early 60s Don Cordier General Chat 4 07-23-2008 11:18 AM
