Sanyo fridge repair? Manual? - Page 2 - Fiberglass RV
Old 03-18-2011, 06:05 PM   #15
Barrie Bochoff's Avatar
Trailer: 13 ft Trillium (sold 1/1/12)
New Brunswick
Originally Posted by Bill K View Post
did you check for 120v going to the fridge ?
They say that changing the heater element is not hard, I have not done it.
Bill K
Hi Bill,
It was the 120v that I tried. I never use 120 service myself. I usually stay in the boonies and when I stay in a campground I never get a serviced site. I thought if it worked on 120v there may be some hope og getting it to work on propane.
I may just take it out and make space for a cooler/ice box. I'll save a lot of weight.
Thanks,
Barrie
Barrie Bochoff is offline   Reply With Quote
Old 03-21-2011, 01:14 PM   #16
Rick G's Avatar
Trailer: former Boler, now 1980 Trillium 4500
Unhappy
Originally Posted by Barrie Bochoff View Post
Hi Bill,
Thanks,
Barrie
It's too bad you are 4000 miles away, I would love to have a look at it before you dump the fridge. Oh well, you know your capabilities/desire to engage in troubleshooting better than anyone. Good luck with your next step.
Rick G
Rick G is offline   Reply With Quote
Old 03-21-2011, 01:26 PM   #17
New Brunswick
Hi Rick,
I'm removing the fridge but I'm not throwing it away. If I find anyone who tinkers with these things it will be easier for me to drop it on they're work bench than trying to convince them to work on it in my trailer. I am willing to try anything myself to get it going but I don't have any sort of manual for it and no experience with fridges. I have tools and ambition and if I had guidance or suggestions I would take a stab at it.
Cheers,
Barrie
Old 03-21-2011, 01:57 PM   #18
Visionsbydarrah's Avatar
Trailer: Littleguy Sliver Shadow 2009
Kansas
So what's a new frig cost these days?
Pat (human) Taz (dog)
2009 Sliver Shadow
2004 Jeep Wrangler X
Visionsbydarrah is offline   Reply With Quote
Old 03-21-2011, 02:59 PM   #19
Rick G's Avatar
Smile
Hi Rick,
Cheers,
Barrie
Hi Barrie,
If you are handy, you do not need a manual, although it can be helpful. Fridges are very simple in concept, and you can probably find out what is the problem yourself.
But before you start troubleshooting the electrical, run the fridge for several hours on propane at the coldest thermostat setting. If the fridge works at all, then you know the cooling tube is probably OK and it is probably worth while fixing the electrical.
The electrical and propane systems are completely separate up to the point where they heat up the heater. If neither works, there is a good chance that your cooling tubes are blocked or the coolant has leaked away. If so, the only possible remedy is to remove the fridge and turn it upside down for a couple of days, which might free a blockage, or take it to a pro for repair, which might cost as much as a new fridge.
There is an excellent resource at : http://www.rvmobile.com/tech/Trouble/Index.htm which has tons of information (possibly too much). I also went through a troubleshooting process on my old Escort fridge (also no manual or internet help) at this post here a couple of years ago: http://www.fiberglassrv.com/forums/f55/3way-fridge-not-working-on-12v-39358.html
I also did a summary of fridge troubleshooting after I removed the fridge from the Boler: http://www.fiberglassrv.com/forums/f54/trailer-fridge-now-working-properly-42642.html
Here is the basic principle: Your fridge is run by one cooling tube filled with chemicals that is heated by any one of three possible sources: propane, 110V, or 12V. If your cooling tube is bad, it will likely cost more to fix than it is worth. If the electric heater element is bad, you might be able to get a replacement, but not likely since yours is an odd brand (although email to Sanyo to see). You would not need an exact replacement, any heater element that would fit into the space would work. Anything else, you can fix or replace.
On my fridge, the thermostat seemed to be working but the electrical connection had shorted over the years, meaning that my fridge ran all the time and froze everything. I was able to replace it with a different model new thermostat that fit into the space and worked fine.
Although you do not have a manual, you should have a faceplate on the fridge itself that tells you the rated power to the electrical heater in watts, and maybe even has a circuit diagram. Assuming that you are handy but don’t have much background in electronics, here is my suggestion to find out what is the problem. I presume that you have a standard digital multimeter that can measure volts, resistance in ohms, and amps. They are available at Canadian Tire for about 10 bucks.
The heater element is a resistance heater, the same as a standard house stove burner, and works the same way. Current passes through and the resistance in the element makes it heat up.
Check to see whether you have a connection in your whole circuit through the heater element. This can be done without using any power or removing anything. If your fridge has an actual plug that plugs into a 110V receptacle (most do), unplug it. Also disconnect the battery positive wire, removing a fuse if you have one or disconnecting the positive battery terminal. Turn the fridge on to the 110V selector switch setting (as opposed to propane or 12V) and turn the thermostat all the way on to the coldest setting (although it should be on anyway since the fridge is warm). Measure the resistance across the hot and negative pins of the AC plug (not the ground pin). You will need the multimeter set on a low range, probably the 0 - 200 ohm range.
As an example, lets assume that your fridge is rated at 100 watts on electrical. This rating would be the same for either 110V or 12V. Your measurement of resistance should be Power = Voltage squared divided by Resistance. For the 110V setting, that would be about 121 ohms for a 100 watt heater. For the 12V setting that would be in the area of 1.5 ohms. These are approximate, since the actual voltage varies in real life.
So, if you get a resistance measurement in the right range for your rated power, you know the heater element is connected and working. By the way, if the whole-circuit measurement of the heater element is in the right range and your fridge is still not working, that points back to the cooling tube again as being the culprit.
If you get a 0 reading, then you have a short circuit somewhere. If you get a very high reading, then you have either a break in the circuit or a really dirty connection. Change the resistance range to higher settings to make sure it is really a break and not just a high resistance. If the short or the break are in the heater element, you would have to replace it, if a replacement can be found. If they are anywhere else, they can be fixed.
So, then I would go right to the heater element and measure the resistance across it the same way. This is because you want to know whether the heater element is toast or not. Your electrical heater element probably has 4 wires coming out of it, two for 110V and two for 12V. You may be able to trace the wires from the voltage selector switch to see which is which. Label the wires if they are not colour coded, or else write the identifying marks down on a piece of paper so that you can identify which wire is which.
In most electrical circuits, only the hot wire runs through the switch and thermostat. The negative (return) wire connects directly to the AC plug negative pin. So, to measure the resistance across the heater element, you only have to isolate the hot wire, and you can use the same connection on the negative pin that you did for the first measurement.
To measure across the heater element without disconnecting anything, turn the voltage selector switch to the 12V setting (disconnect the trailer battery from the fridge as you do not want power going to the fridge at all). This disconnects the 110V circuit from everything else. You can then find the 110V wire that goes to the heater from the selector switch, and measure it across the negative pin of the AC plug, which is the return wire. It does not matter whether you measure at the heater element or a wire that connects directly to it, electrically they are both the same.
If the heater element measures in the right range, but there was a 0 or very high reading in the previous test, then the intermediate wiring, switch or thermostat is the culprit. All can be replaced or repaired fairly easily, as they are components which are still used today and you do not need an exact replacement.
To find out which wire is connected to what, you can use the multimeter to measure resistance at the places you suspect are the same wire. The same wire will have 0 resistance, or very close to it, whereas if you are measuring two unconnected wires it will have infinite resistance. If you measure some value in between, then the wires are connected to each other through something else, either a component or a leak somewhere.
Complicated? Not really, once you get the hang of it. Let me know if you decide to undertake this, and what your results were, and we can take it from there.
Hope that helps,
Rick G
Old 03-21-2011, 03:19 PM   #20
New Brunswick
Wow! Thanks Rick. You have provided a lot of information. It will be a lot easier for me to tinker with it when I'm warm and working in a warm shop. There is writing on the fridge but with my old eyes I'm having trouble reading it where it's located. I am going to take a stab at it; nothing to lose, right?
Thanks again very much. I enjoy learning and this is a piece of equipment I've never worked on.
Cheers,
Barrie
fridge
Manual Wanted dave c. d Care and Feeding of Molded Fiberglass Trailers 6 01-06-2010 09:14 AM
Need Suburban GT 10 D Manual mszabo Problem Solving | Owners Helping Owners 5 10-07-2009 09:57 AM
Dometic refrigerator repair manual Rick kl Forum Admin, News & Announcements 1 07-06-2009 07:03 PM
another manual BillNKC Forum Admin, News & Announcements 0 08-11-2006 05:26 AM
