When I bought my 1978
Scamp 13 the trim at the entrance was loose, and kind of flopped around!
Today I removed the two metal pieces of trim to make whatever repair that is needed.
I learned two things: One on the two pieces of aluminum extrusion was attached to the Scamp's 1/2-inch plywood floor with three !/8 th rivets!
Then the second piece of aluminum extrusion was attached to the first trim piece with three flat head bolts.
My questions is whether these two aluminum extrusions were originally installed by
Scamp Co. ( Rivets into wood?)
Here are two very poor quality photos:
Showing the entry way with the trim laying on the driveway.
ID: 93706" style="margin: 2px" />
Two trim pieces on work bench. The wood floor would be inserted from the right side of the trim. The three flat headed bolts did not pass thru the wood floor!
Is this type of doorway trim the correct trim for a Scamp 13 trailer?
Any comments or suggestions will be appreciated.
Bill
