Scamp 13' door hinges - Fiberglass RV
Old 09-11-2009, 09:52 PM   #1
Trailer: 1992 13 ft Scamp
My Scamp came home from the paint shop and now it's time to re-assemble.
Today we started installing the door with the new hinges purchases from Scamp. It seems that the new hinges stick out farther then the old one's. In return makes the door stick out farther at hinged side. Is it possible to add 3/16 aluminum spacers behind hinges attached to door? Or is it easier to just polish existing hinges and re-install? Any help will be much appreciated.
Thanks,
David
DavidS is offline   Reply With Quote
Old 09-11-2009, 10:03 PM   #2
Thanks,
David
In addition the top hinge was installed crooked from factory, sure wish I noticed it before.
Old 09-12-2009, 08:01 AM   #3
Trailer: 2014 Escape 21
Virginia
You should be able to buff up the old hinge, just use a wire brush or a dremel tool. I would use the ball and spring from the new hinges. I would also replace the hinge bolt and nut with stainless hardware. I normally replace all hardware with stainless fastners whenever possible to prevent rust and streaking.
I you choose to use a spacer with the new hinges just make sure your attaching bolts threads extend pass the nut.
Eddie,
Old 09-12-2009, 10:27 PM   #4
Eddie,
Thanks Eddie, I started polishing the old hinges with the dremel tool today. I put the the
old hinge next to the new hinge that was mounted.There's a 1/4 inch or more difference that the new hinge sticks out more than the old, making the hinged side of the door stick out more. The gap is so large that the weather stripping would not seal.
Old 09-12-2009, 11:21 PM   #5
Raya's Avatar
I wonder if something has gone wrong with their hinges? I can't figure out how the ones you describe would work on Scamps then either. I mean, the door in them sits flush with the opening too, doesn't it?
Is one "leg" of the hinge longer (sounds like it must be)?
Can any Scampers give any insight?
Raya
Old 09-12-2009, 11:41 PM   #6
Roy in TO's Avatar
I wonder if there is a difference in hinges like on the old bolers. The upper had a #2 stamped on it and the lower a #1. (or vice versa)
Old 09-12-2009, 11:52 PM   #7
Roy, I looked at that the hinges appear to be the same. After installing the new hinges I noticed how large the gap was between the door and opening surface. I then placed the old hinge next to the new and there's a sizable difference. I considered putting shims on the door side of the hinge to move door closer to opening. Maybe, I'm doing something wrong.
Old 09-13-2009, 01:49 AM   #8
Raya's Avatar
It would be interesting to get to the bottom of this. I know that a number of Bolerites have considered buying the Scamp hinges as replacements, so there would definitely be people in your wake who would be interested in what you're finding.
Would you be able to post photos of the hinge problem?
I wonder how this is affecting new Scamps. Have they changed the door or body mold?
Yes, on my Boler the top pair of hinges both have a number 2 on them, and the bottom pair of hinges both have a number 1.
Another thought: Were you using the new hinges in the old mounting holes, but the new hinges need differently spaced mounting holes?
A picture would be worth 1,000 words, if you could post one.
Raya
Old 09-13-2009, 05:30 AM   #9
All good points Raya! David please let us know what year your trailer is too. Your profile doesn't give us that information. Occasionally that little bit of information is enough to track the differences.
Old 09-13-2009, 09:11 AM   #10
Roy in TO's Avatar
David,
Can you measure and post the lengths of the hinge arms both body and door side?
Both old and new.
Are upper and lower the same?
Old 09-13-2009, 05:42 PM   #11
David,
Both old and new.
All,
It's a 1992 Scamp 13'. Yes, I'm using the existing holes for new hinges the holes seem to line up perfectly besides the out of plum top hinge the factory installed. Today I went and measured the hinge difference and it's the problem by far. There's a 5/8" difference between the new to old hinge finding the new hinge bigger. I polished up the old hinges and they look great. I will post some pics. of my findings within the next couple days.
Also, the new hinges will work with some modification of course and they are going back to Scamp.
Thanks,
DavidS
Old 09-13-2009, 05:53 PM   #12
Roy in TO's Avatar
Is that 5/8" difference on both arms or just one?
Old 09-13-2009, 05:58 PM   #13
Roy,
That would be both arms.
Old 09-13-2009, 06:56 PM   #14
Raya's Avatar
I'm probably a bit slow, but I'm still scratching my head a bit to try to visualize this.
I understand your use of the old hinges; why not, since they fit and are reusable. But the curious side of me still wants to figure out how Scamp is using these on their new trailers, since it doesn't look like the basic geometry of their doors has changed.
Would it have been a matter of putting the fastener holes in new places to have made them fit?
Is there any chance you could post a photo that shows the difference?
Thanks,
Raya
13 ft boler door hinges steve J Problem Solving | Owners Helping Owners 1 09-11-2009 09:01 PM
Door Hinges Phillip Modifications, Alterations and Updates 8 06-23-2009 02:34 PM
Door Hinges Wayne Boone Problem Solving | Owners Helping Owners 5 04-18-2008 09:05 PM
Looking for some Door Hinges.... mcnick Problem Solving | Owners Helping Owners 23 06-18-2007 06:52 PM
Looking for some Door Hinges.... mcnick General Chat 0 12-31-1969 07:00 PM
