Scamp 13 Furnnce Question - Fiberglass RV
Old 04-14-2015, 03:31 PM   #1
Bill Nolen's Avatar
Trailer: Had Scamp 13', want another small trailer.
My 1978 scamp 13 has a furnance different than any I have seen before.
Here are two photos showing it. One the outside vent, and the other the front cabinet.
I'd greatly appreciate knowing the make of the furnance, and if anyone has any owners manuals, or knows where I can find such, and how does a person remove the furnance from the cabinet!
I haven't been able to open/remove the lower opening for fear of damaging it, as it is stuck shut! Should it be opened by pulling outward on the lower knob?
Help!
Bill
Bill Nolen is offline   Reply With Quote
Old 04-14-2015, 04:02 PM   #2
David Tilston's Avatar
That is a Wagon Master furnace. Pull outward on the knob. It may be rusted shut and require some prying. There will be a gas valve under that cover, and a pilot light port that will allow you to light the pilot, and to adjust the thermostat.
Furnaces of this age may have holes in the heat exchanger. You should have a CO detector if you plan to use it.
Also the gas valve may have packed it in. This might cause it to not light the main burner, or never turn it off. If the pilot won't light, that might be fixed with a new thermocouple.
Removing the furnace is hard to do with out destroying it completely. The exhaust vent is probably two pipes that telescope, or did at one time. The heat and moisture in the exhaust typically cause these two pipes to rust together.
Old 04-14-2015, 04:24 PM   #3
Bill Nolen's Avatar
David, thank you very much!
Looking from the inside of the cabinet I could see what I thought was a single exaust pipe.
Is the front of the furnace renoveable, for cleaning, and perhaps replating or painting?
It's unlikely that I would ever use the furnace, but I would like it in SAFE working order if I leave it installed.
Bill
Old 04-14-2015, 04:25 PM   #4
Bill Nolen's Avatar
Is the front of the furnace renoveable for cleaning, and perhaps replating or painting?
Bill
Old 04-14-2015, 04:36 PM   #5
Trailer: 77 Scamp 13
Might also need to lift up (or move up with a gentle tap) that lower panel before pulling out on the bottom of it.
One dead simple device but also a design that is older than dirt. If you want to use it then it would probably be a good idea to find a propane place or furnace guy willing to do a check up. E.G check for leaks in the heat exchanger. You may have to try a few places as some may not want to touch anything as old as this.
That furnace is just a box that has a burner inside another box. With nested chimney pipes. One to bring in combustion air and one to exhaust combustion gases. Air flowed by convention along the hot metal box. Not much to go wrong but no safety devices if something does go wrong. Such as CO leak from combustion box.
Here is a link to a diagram http://www.fiberglassrv.com/forums/a...1&d=1287185795
And a link to lighting instructions see post #4. Duo-Therm gravity furnace not working properly
Using the site search (Google option at the bottom) and searching for Boler gravity furnace. Or Scamp gravity furnace should net you some leads too.
Lot of folks like these old style furnaces because they have silent operation and no power consumption since they have no fan. Plus lack low oxygen sensor that prevents some newer furnaces from working at high elevations with less oxygen.
Others would rather not run a gas appliance that has been out of production for many years and lacks modern safety features. Just be aware that what the furnace lacks in safety features you have to make up for with your actions.
Old 04-14-2015, 04:53 PM   #6
Bill Nolen's Avatar
Roger, thank you very much for the great information!
That is good advice about having it checked for leaks. I have a good friend who is a retired heating and AC repairman. He might still have the necessary equipment to make that check for me.
Again, thank you, and David for your help!
Bill
Old 04-14-2015, 06:30 PM   #7
Bill Nolen's Avatar
Roger, I have an additional question.
Do you have the thread that contained the drawing for the furnace drawing? I'd like to contact the person who posted the drawing. They might have the owners manual?
Does anyone know whether the Wagon Master furnace is the same as the Suburban GT-100? This owners manual is in the Fiberglass Rv Documents.
Bill
Old 04-14-2015, 08:10 PM   #8
Here a pro can loose his licence if he worked on it! and its not simple due to its age.
The OP may want to read the following thread and decide if the continued risk in using it is worth it.
Your Wagonmaster heater may kill you
Old 04-14-2015, 10:13 PM   #9
Bill Nolen's Avatar
Carol H., I appreciate your concern, and information. I did read the listed thread, and it appeared to me that the messages were about equal in opinion about the safe or unsafe use of the Wagon Master Furnace.
As I stated in message 3 above "It's unlikely that I would ever use the furnace, but I would like it in SAFE working order if I leave it installed."
And, at this time, I have considered removing all LP items...stove, furnace, and LP tank. Not for safety reasons, but to lessen the weight and make it a very simple RV.
However, I am interested in who has the authority to "ban" the use of this furnace. As far as I know a manufacturer has no such authority. They may issue recalls, and refuse to sell parts for their products.
Of course, I guess some RV Club could ban anything they wish, as long as the members will go along with the ban! No pink flamingos in the RV space for example.
Does anyone here know where a battary operated carbon monoxide detector might be purchased? All I've seen are powered by 120 volts, with a small battery backup...which I don't think would operate very long in the boondocks without 120 volt power.
Bill
Old 04-15-2015, 07:31 AM   #10
Bill, our local Walmart has battery-only CO detectors. I installed one in my Scamp so we could use the furnace on a fall trip last November. Hardware stores, Home Depot,... shouldn't be hard to find. If not, then Google it and you'll find plenty of online sources.
Old 04-15-2015, 07:47 AM   #11
Bill Nolen's Avatar
Thanks Jon!
I shouldn't have assumed they were all powered by 120 volts because that was what I bought!
Bill
Old 04-15-2015, 08:50 AM   #12
Bill
While your correct its pretty impossible to totally ban the use of this type of thing and actually in force it, but what can happen is what you described. The manufacture stops making the item, can issue a recall (possible even a forced one by the Governing state/provincial/federal body) and stop selling parts for it. The Governing party can also issue an order to those with a licence to repair the item to stop repairing them or risk losing their professional licence. All of which is what has happened in regards to the WagonMaster Furnace.
Nothing to do with RV clubs. All RV clubs and members of fiberglass trailer forums can do is try and educate folks on the topic. Which is what apparently happened at one of the Fiberglass trailer meets - its not the first time thats happened at a meet either. As they say Carbon Monoxide is a silent killer.
As with all things at the end of the day once someone has been made aware of a serious safety issue such as this its up to the individual to decide what level of risks they are willing to take with themselves and their family members who may be camping with them in order to save some money. Keeping in mind that today there are a number of safer options to heating a trailer without the use of electrical power and not totally run the battery power down.
Old 04-15-2015, 09:00 AM   #13
Actually they are dead simple, even if they are old. There are some important considerations though. Primarily that the heat exchanger doesn't leak, then the gas valve has to work. If it doesn't work it can be replaced. It may take some shopping though. I found a gas valve that will work on my furnace for about $100, but the ports are in different places, so some tube bending is required. I suspect that you have to match up the btu input. I recently purchased a furnace that has the same basic design, and the same input btu's. I will try to use the gas valve off that.
Since they are so difficult to remove, find someone who will work on it while it is installed in your trailer.
Carole, I find it difficult to believe that a licensed furnace service person would get in trouble for repairing an appliance that was CSA approved in it's day. That is like saying that a mechanic would loose their license for working on a Model T because it doesn't meet current crash standards.
Please leave the CO argument alone. This style of furnace is no more likely to develop a leak, or cause CO poisoning then any current design. The reason they no longer meet CSA standards is all about surface temperature.
Old 04-15-2015, 09:43 AM   #14
I, for one, think that anyone that has to ask basic questions about a gas furnaces workings needs to go directly to a licensed (or at least experienced) furnace technician for hands and eyes on inspection.
A 35+ year old furnace that has been continually exposed to outside elements, via a very short vent, can well be akin to the old gas chamber at San Quintin prison and can lead to the same end result.
Remember, while certain STD's are forever, it's not so with gas furnaces.
As it turns out, just this a.m., there is a furnace tech due where I am staying to repair a burned out junction block on our electric furnace. As this is an LP/Electric only area, with thousands of RV visitors every year, I will ask his opinion on the question as well.
Answer a Question then Ask a Question CarolnJim General Chat 77 06-03-2006 11:39 AM
