Scamp 13 Heat Anticipator Setting? - Fiberglass RV
Old 10-05-2014, 11:11 AM   #1
Trailer: Scamp 13'
I just tried to start furnace and found that the heat anticipator was in a netural setting. It has never been set and was wondering what to set it at. The furnace is a Suburban NT-16SE with a heat only thermostat. Thanks, Mike
Mike-N-Laurie is offline   Reply With Quote
Old 10-05-2014, 12:20 PM   #2
Trailer: 2010 Escape 17B
My instructions which include your model say .7
kootenaigirl is offline   Reply With Quote
Old 10-05-2014, 12:55 PM   #3
Trailer: Scamp 13'
I've been searching the web for an hour.
The heater has never been set.
Thanks
Old 10-06-2014, 12:16 AM   #4
Regardless what the anticipator is set at, the furnace should come on normally. You can jumper it also. If I remember right the sequence should be something like this. Set point is reached, turn thermostat all the way up, the fan should come on to purge leftover gas fumes in the heater, glow igniter should glow red and then gas should come on. Good luck
Frank F
frankcfx is offline   Reply With Quote
Old 10-06-2014, 07:05 AM   #5
Trailer: Casita 17 ft DLX SD
Set the anticipator to the amperage / current raring of the gas valve . You can usually find the voltage and current ratings on the side of the gas valve . The furnace will run even if the anticipator is incorrectly set but it may short cycle or over shoot the set point . Normal household furnaces usually have a current rating of .4 A at 24 V not sure for an RV furnace
steve dunham is online now   Reply With Quote
Setting Your Trailer Brakes ronsmith100 Towing, Hitching, Axles and Running Gear 3 04-21-2009 03:05 PM
Prodigy brake controller setting? Christi V. General Chat 15 02-16-2008 12:21 PM
Setting up a new workshop? Pete Dumbleton General Chat 10 01-09-2008 07:07 PM
Setting Up city Water Bonnie Problem Solving | Owners Helping Owners 4 11-14-2007 02:45 AM
Fix your board setting for time Donna D. General Chat 1 11-05-2007 07:51 AM
