Scamp 13' License Plate screws - Fiberglass RV
Old 09-06-2017, 09:17 AM   #1
Trailer: Scamp - Gently Used
Kentucky
I am looking to mount the license plate on our new 13' scamp but the screws from pepboys are to long. I am afraid the end of the screw will rub the fiberglass. How did you mount your license plate?
Kris & Scott | 13' Scamp Standard | 2014 Mazda CX-9 Grand Touring
RogueIT is offline   Reply With Quote
Old 09-06-2017, 09:26 AM   #2
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
I've always bought stainless steel license plate screws at my local Ace Hardware. Since they have many different lengths, I can touch the screws to measure them unlike at the big box stores (Home Despot, etc.).
Old 09-06-2017, 09:39 AM   #3
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
You can use plastic bolts (screws) and put them in with the heads toward the Scamp. If the arms of the license bracket are metal, you can bend them outward away from the fiberglass.
Old 09-06-2017, 10:07 AM   #4
Simple solution to a simple problem. Reverse the bolts so the head is on the toward the trailer.
I used SS bolts instead of Screws. I used what I had in junk box.
Old 09-06-2017, 12:04 PM   #5
New Hampshire
Scamp license plate screws
Hi. I also found it somewhat challenging to attach the plate without damaging the fiberglass. I purchased 1" stainless bolts with washers & lock nuts. The bolt head is behind the plate and the washer & nut is on the outside. Make sure the bolt has a hex head and not one slotted for a screwdriver. A small open ended wrench holds the bolt while nut is tightened. Once done, you shouldn't have to deal with it for years. Good luck.
BSinNH is offline   Reply With Quote
license, scamp
Backside Bling for BEAN (tire cover/license plate cover) Vickie B. Modifications, Alterations and Updates 12 03-02-2011 06:31 PM
Installing a Backup Camera on the TV License Plate Kevin A Problem Solving | Owners Helping Owners 8 12-28-2009 08:07 PM
Smaller license plate shane n Modifications, Alterations and Updates 2 08-01-2009 07:48 PM
Putting a new license plate on a Scamp Monica M General Chat 6 05-27-2009 10:28 AM
Casita License plate costs Keith Williams Problem Solving | Owners Helping Owners 19 04-27-2009 06:30 PM
