Scamp 13' Roof Vent ?? - Fiberglass RV
Old 02-05-2011, 11:19 AM   #1
Trailer: '84 Scamp 13' & 2001 Casita 17' Spirit Deluxe
Arkansas
My 'new' 1984 Scamp 13' is missing the 15x22" roof vent. Apparently it was broken & the PO replaced it with a sheet of stainless steel. I'm planning to replace the stainless with a roof vent but would like to use a Fantastic Fan. The Fantastic Fan requires a 14.5x14.5" (approx) cutout. Has anyone here ever installed a Fantastic Fan in the original roof vent location? If so what method did you use to reduce the cutout? Perhaps I'd be better off just replacing the stainless with an original size vent & adding the Fantastic Fan in another location?? Any advice/tips appreciated. TIA.
This how it looks now (yeah, I know I got a lotta cleaning to do)
Harvey is offline   Reply With Quote
Old 02-05-2011, 12:03 PM   #2
Arkansas
Guess I need to learn to do a better job with the Search function . I found the thread with Donna's post about the 'Escape/Egress Hatch' so I'll replace the stainless with an original roof vent/escape hatch. Will hafta look at the roof a little closer to find a location for the Fantastic Fan. I do have an old 18x24" radius corner window with the red 'Emergency Egress' handle from a mid-90's camper that I might could use to replace one of the Scamp's side windows??
Old 02-05-2011, 06:34 PM   #3
Two vents are better than one. Especially is one is a power vent. One forward, one aft and you'll get great ventilation without the need to open the windows. If the non-powered vent has a MaxxAir vent cover on it, you can leave it open in the rain..
Old 02-05-2011, 08:50 PM   #4
Trailer: Fiber Stream
On all the Scamps I've seen with a Fantastic-Fan, they mount it just forward of the "Escape Hatch" roof vent with only a few inches between the two.
Old 02-06-2011, 03:20 PM   #5
Perry J's Avatar
Trailer: 16' Casita
I installed my fan over the bed area so I have a little breeze on hot nights.
Old 02-06-2011, 08:29 PM   #6
If your stove doesn't have a vent hood, consider putting the power vent on the roof dead center of the kitchen area, so when you boil something, you can remove the moisture quickly.
Old 02-07-2011, 07:16 PM   #7
Trailer: 2014 Escape 21
Virginia
Harvey
I think this is the replacement for the origional hatch. You might want to call and make sure. Even though it says the frame is alum. the orig. and replacement vent fame is plastic. I have replaced several plastic frame hatches and when I do I cut out a plywood ring around the vent on the inside and screw the vent and trim ring to the plywood.
Eddie
15 x 22 Elixir Vent Lid - $55.60
Old 02-07-2011, 08:26 PM   #8
Arkansas
Thanks Eddie. Wuz lookin' at that one. Still not sure but reading the description it appears you're only gettin' the lid & not the complete vent assembly?? I'll give 'em a call & check it out. If it is the complete assembly, that's a lot better price than from Scamp, even with shipping.
Old 02-09-2011, 12:41 PM   #9
Virginia
Harvey
I remembered I got mine from Tweetys.com. I think this is what you want, the one with the plastic frame. Again call and make sure.
Eddie
Heng Exit Vents
Old 02-10-2011, 08:59 PM   #10
I installed a Fantstic fan at the back over the rear table/bed behind the main escape hatch. Works well.
To Roof Vent, Or Not To Roof Vent Frederick L. Simson Problem Solving | Owners Helping Owners 5 02-22-2009 04:41 PM
Replace roof vent on Scamp with fan? Conrad S. Care and Feeding of Molded Fiberglass Trailers 2 05-13-2008 06:45 PM
13' Burro roof Legacy Posts Problem Solving | Owners Helping Owners 2 02-24-2003 03:53 PM
Weird Vent in 13' Scamp Legacy Posts Problem Solving | Owners Helping Owners 26 12-27-2002 09:35 PM
Roof Vent Kevin K General Chat 0 12-31-1969 07:00 PM
