Scamp 13" tires - Fiberglass RV
Old 08-09-2015, 09:50 PM   #1
Trailer: Escape 19’ (had Scamp 16’)
Question Scamp 13" tires
Noticed major tire problem on our 16' Scamp recently. Blowout probably would have occurred in less than 50 miles if I hadn't looked underneath and noticed chunk out of inside of tread. I'm concerned that with our side dinette floor plan with our oversized fridge, awning and a/c, that we are too close to the load limit for the standard load rating C tires, at least on the door side where we had the tire issue. I found only one 13" radial tire with a D load rating. It's made by Kenda and I can only find them online, complete with wheels to handle the extra air pressure and/or load. Anyone tried these Kenda Karrier D load rating tires yet?
ColoradoSwany is offline   Reply With Quote
Old 08-09-2015, 10:27 PM   #2
Have you weighed your trailer for total and side to side weight.
How many miles were on the tire you removed and what was it's date of mfg.
"D" range isn't a real high load rating, nor is the 65PSI inflation pressure, so your original wheels will work fine.
Old 08-09-2015, 10:46 PM   #3
Bought our Scamp last fall and have not had it weighed yet. Trying to figure out where I can get that done.
Unfortunately, I didn't think to check date of tire manufacture until after I'd replaced it. When we got the Scamp, the tires looked great, though we had 3 different brands! I noticed on this latest trip that this door side tire had worn severely on the edges as though it had been under-inflated even though we put no more than about 2800 miles on it and I checked pressure before every trip, always keeping 45-48 psi.
i hope to get it weighed before next season AND get fully matched tires. Any ideas on where I can get it weighed?
Old 08-10-2015, 04:52 AM   #4
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
IMHO, the best 13" trailer tires on the market are the Maxxis M8008. If you have a local Discount Tire, they will order them or you can buy from them on line.
2 NEW Maxxis M8008 ST Radial 175 80 13 TIRES R13 80R13 | eBay
Old 08-10-2015, 06:03 AM   #5
Sands's Avatar
Trailer: 2003 Scamp 16'
Have not used Kenda trailer tires but I've used Kenda tires on my Nissan 4x4 and on my mountain bike, both with good results. They make a quality product that (in my experience) holds up as well as more familiar names.
Sands is offline   Reply With Quote
Old 08-10-2015, 06:21 AM   #6
I didn't care for the lack of extra capacity on the available 13 inch tires for my 16 foot Scamp so when I changed axles and I had to buy new wheels anyway for the 5 lug brakes and hubs I moved up to 14 inch wheels and tires. This meant new wheel wells etc.
I now have more safety margin and slower turning wheels.
Sent from my SCH-I605 using Fiberglass RV mobile app
Old 08-10-2015, 07:38 AM   #7
Colorado looks like a pretty big state so it's difficult to provide an exact location for getting weighed, but here's a few tips:
1. Truck stops often have scales for trucks and can also provide left/right balance info.
2. Scrap yards, gravel/landscape supply yards and trash transfer stations usually have scales.
3. Google "Public scales"
FWIW: The comment "tires looked pretty good" is usually what's said after an overage tire failure.
Old 08-10-2015, 10:01 AM   #8
Ohio
Trailer Weight
I got mine weighed at the local land fill for free. It came it at 3000# on the nose. That was unhooked from the TV. Holding tanks were full.
You can also get it weighed at truck stops for a fee such as Pilot ir T&A.
Some states will do it at weigh stations for free but suggest you call first.
My stock 13" Sccamp wheels are rated @ 1344 lbs each. The tires are 1360 lbs.
I need to weigh the tongue so that I can subtract that from the total. when I run dry I should be within the weight limits. I have had the tires wear, on other trailers, on the inside tread when overloaded but never had any chunks come out. hehe
cmartin748 is offline   Reply With Quote
Old 08-10-2015, 12:39 PM   #9
Mike Magee's Avatar
Trailer: Li'l Hauley
I bought one of these scales, so each side of the trailer can be weighed independently:
Sherline Trailer Tongue Weight Scale - 2,000-lb Capacity Sherline Tools 5780
If you get one, don't put it under the torsion axle tube because it can bend the axle.
How to prepare Tofu
Step 2: grill some meat
Old 08-10-2015, 06:21 PM   #10
Manitoba
I noticed this week with my 2014 Scamp 16 side dinette with large fridge, that my right side tire( curb side) was badly worn on the outside. I checked the toe in and found it to be towed in approx. 3/16"- 1/4" measured approx. 6-8"above the ground. I emailed Scamp this morning but have not received a reply yet. I spoke with my local trailer shop and they suggested a new torsion bar axle assembly, as there is no adjustment on these. What is your experience in cases like this?
Jim
Manitoba Jim is offline   Reply With Quote
Old 08-10-2015, 07:37 PM   #11
Don't bother emailing Scamp, it can sometimes take a week for a reply. Phone them and follow up with a letter. And what the heck is a "Torsion bar axle assembly" ?
if nothing else I would suspect a bent trailing arm.
Old 08-10-2015, 07:44 PM   #12
IllAnnoy
I have Kenda Qwest bicycle tires on four of my bikes... its like having Bontrager AWs at a fraction of the cost and I like the look.
Old 08-10-2015, 08:33 PM   #13
Manitoba
Bob
What the heck do you call it. You know what I am talking about. Can a bent trailing arm be straightened?
Jim
Old 08-10-2015, 09:25 PM   #14
I don't know if they are stamped or cast... I'd take it to a frame & alignment shop to have them measure if one or both sides are toed in. They can do something called a "Centerline Alignment Check" I'd also contact the axle maker and see if there is a specification for tow in.
A good frame & alignment shop should be able to at least determine the exact problem. You may also be able to just replace the trailing arm. Again, ask the axle maker for specs and a parts breakdown.
scamp, tires
Free 13" 4"x4" rims, bolts, tires and air Oshkosh, WI heypizon Parts: Buy | Sell | Trade 0 06-07-2015 12:08 PM
13" Tires or/vs 15" Tires? Tony Rubi Problem Solving | Owners Helping Owners 9 10-31-2013 10:35 PM
wooden "tires" for winter storage? GordM Care and Feeding of Molded Fiberglass Trailers 12 08-16-2010 05:59 PM
Some "before" and "after" shots..... Don & Viv Modifications, Alterations and Updates 13 07-29-2010 04:52 PM
