Scamp 16 Fresh water intake - Fiberglass RV
Old 06-01-2013, 06:19 PM   #1
Fulltimer West of the Rockies
I just purchased a 98 Scamp 16. The smell I thought was Wall Fur or old carpet was mildew. I pulled out the fresh water tank and the floor is soft. I'll let it dry out and I'm thinking of using Polyurthane glue and a sheet of Lexan that I have laying around to reinforce it. I'm looking at the corrugated hose coming in and I see it slips over the male tank fitting. There wasn't any clamp only caulk that obviously wasn't working.
I'm thinking of wrapping then together in electrical tape, then slipping a slightly larger hose over that and then a hose clamp
Since I'm using the Lexan I think I'll put 4 eye hooks at the bottom so I can strap the tank down. I think I read where there are 9 gallons which makes 72 pounds bouncing around.
So far I'm seeing this as a minor problem so no buyers remorse. Any and all comments welcome
Thanks Bob
bobflhtc is offline   Reply With Quote
Old 06-01-2013, 07:13 PM   #2
David B.'s Avatar
I've replace our corrugated hose twice (leaks), and finally replaced it with the clear hose that has a webbing built in it. This really seals well to both the tank and the filler. The tie down sounds like a much better idea than the 4 small screws into the wood through the loose metal strapping. I used 2x2's screwed into the wood to make a "box" around the tank so it wouldn't walk around during travel and secured it with mule tape.
Dave & Paula
Old 06-02-2013, 06:18 AM   #3
kirkman's Avatar
Trailer: 2007 Eggcamper & Homemade Tear Drop
Bob
If you floor has any fiber glass or just resin on it now it's probably Epoxy> Polyester resin will not stick to epoxy. Epoxy will stick to ether polyester or epoxy. You could call scamp and find out what they used.
Good luck!
Jason
kirkman is offline   Reply With Quote
Old 06-02-2013, 07:12 AM   #4
KevinPete's Avatar
Trailer: 1995 Scamp 13
Welcome, Bob! My 1995 13' Scamp has the same issue, soft floor under water tank, hasn't rotted through or anything, but I want to stop it before it does. I don't understand the part about the electrical tape and larger hose, if it was just going over the male fitting I'd just clamp it, or at most use a food-grade silicone and a clamp.
The lexan and PU glue would make it easier to clean the bottom of the compartment, but if water gets in another way it will hold the moisture in the OSB. A couple spacers might allow air circulation.
KevinPete is offline   Reply With Quote
Need to know about upgrading Scamp 16 fresh water tank to 20 gallons SharonM Modifications, Alterations and Updates 21 02-25-2013 05:22 AM
Trillium 4700 Water Intake Caps? kesslinger Problem Solving | Owners Helping Owners 8 10-20-2012 05:00 PM
Auxiliary Fresh Water Tank, Transferring Water Adrian W General Chat 0 09-05-2010 02:36 PM
Compact II fresh water intake and sealing windows??? Pat Goodwin Problem Solving | Owners Helping Owners 5 01-24-2009 05:48 AM
Trouble adding water to a fresh water tank Dan Tracy Problem Solving | Owners Helping Owners 1 05-05-2008 08:11 PM
